Custom 16G6 Turbo Project
Old May 19, 2005 | 05:45 AM
MalibuJack's Avatar
Originally Posted by AznFlip
Isn't the stock lancer manifold flange is cast iron right? and 44mm steel manifold from ebay is good enough?
Well for the battery, I'll have to see it first, if it will be on the way I'll get a mini batter like you said.
Thanks,
JOhn
Yah, Most cars the stock manifolds are cast.. You'd definitely have to find a flange thats at least mild steel, you should really try to find stainless so you get a much better quality weld (and it'll look better)
There's a few other things you will have to address (besides engine durability) since you'll have to alter or replace your MAF.. You can get an EVO MAF, and call up Splitsec (www.splitsec.com) and get one of their Karmann devices to calibrate an EVO maf to the stock ECU, or you can do nearly the same thing with an S-AFC..
Before you get too deeply into this though, get some prices for beefed internals and going over your engine with a fine-tooth comb (blueprint rebuild) so it can withstand additional cylinder pressures..
There's no doubt this is a project.. But its fun and your fortunate that many evo parts can be adapted fairly easily..
Old May 19, 2005 | 07:20 AM
livelyjay's Avatar
That's what I am planning for the future. Maybe not blueprinting, but definitely forged internals and possibly heat coating them as well, PP, etc.
Good luck with the project and make sure you get pictures of everything. I'd really like to see the turbo mani they build for you.
Old May 19, 2005 | 05:03 PM
AznFlip's Avatar
Yup, I will difenitely take pictures of every update and I plan to beef up my internals later this year and boost around 12-13.... But for now I need to sell my RRM Header version 2. I need cash asap.
Old May 19, 2005 | 05:13 PM
MalibuJack's Avatar
Ya know.. you can save yourself some time by using your header as the donor for the flange... Assuming you don't sell it..
Old May 19, 2005 | 05:16 PM
AznFlip's Avatar
Good point. But I'll try to ask Rob from RRM if they have extra flange setting around....
Old May 20, 2005 | 06:55 AM
HobieKopek's Avatar
Get a piece of sheet metal and get to tracing and transferring. Take a rubbing with a piece of charcoal. Should be easy as pie.
Old May 20, 2005 | 07:02 AM
livelyjay's Avatar
Who made yours? What was the price tag? I'd like to get one made for me, since the RRM piping is a but much.
Old May 20, 2005 | 08:10 AM
HobieKopek's Avatar
https://www.evolutionm.net/registry/viewride.php?vid=75
Old May 20, 2005 | 09:05 AM
MalibuJack's Avatar
I had some stainless stuff cut on a water jet locally.. Their not in business anymore, but I'm sure there's gotta be something local that can do it for you..
Old May 28, 2005 | 12:43 AM
AznFlip's Avatar
Updates
Just bought:
Hallman Pro Kit MBC
SS Evo Manifold
SS Evo O2 Housing (came with the deal)
Going to buy next...
Stock Evo 8 upper ic pipe
Oil line kit (Cheapturbolines.com)
Forge Motorsports adj wastegate actuator w/ 5lbs spring
I just forgot forgot what else to buy... I'm sure I'll buy gauges later...
S
Old May 28, 2005 | 12:45 AM
Hotshot940's Avatar
Originally Posted by Blacksheepdj
Personally, I don't think turbo is a "on a tight budget" kinda project. If you can't afford to do everything safely, don't do it at all.
Use the money for the wastegate to start saving for internals.
Tru dat.
Old May 28, 2005 | 12:49 AM
AznFlip's Avatar
Originally Posted by Hotshot940
Tru dat.
Not anymore... Me have more dinero
Old May 28, 2005 | 01:02 AM
rhyzin's Avatar
crack dealer
AznFlip's Avatar
Originally Posted by rhyzin
crack dealer
Old May 28, 2005 | 01:07 AM
Hotshot940's Avatar
Well in that case, wanna send some my way? I only put a car and a half on a stage 1 SRT-4, i need more
