Just installed non-ic rrm turbo!
Old Jun 29, 2005 | 05:41 PM
Kelspar's Avatar
Ok well got boost readings.......i have blitz dual TT. It said .43 Hkpa(?) was the peak. Im assuming thats not even 1 psi? Well i dont know what it translates too but im going to look it up. Havent had chance to look for exhaust leaks b/c car is super low to ground in front (evo VII extreme bumper [the one with the fat *** lip]). Also, i checked all the connections on the intake side; they seemed fine although i did tighten the turbo outlet (intake side).
-Heath
Old Jun 29, 2005 | 05:46 PM
HobieKopek's Avatar
Originally Posted by noriceoz
or buy a evo and problem will be fixed
I thought it would at least be an Evo guy playing the jackass. Check for exhaust leaks, THEN check for boost leaks. Exhaust are much easier to find. If it's post-turbine...don't worry about it for terms of boosting, but if it's before...you have a problem, and it certainly could explain the noise. If not you can either buy or make a pressure tester kit.
Old Jun 29, 2005 | 05:52 PM
Kelspar's Avatar
ok. Well from this post it says that an hkpa is equal to .07 psi. so (im a little rusty at math) but i should divide my peak (.43) by .07 and it would give me psi? if so its like 6.####### Not trying ot sound dumb; just reporting back with boost findings. I will check for exaust leaks too. I assume there is a post on how to build a custom pressure tester kit? (im going to search)
thanks again,
heath
Old Jun 29, 2005 | 05:53 PM
grubiaco's Avatar
Originally Posted by blaze_125
That's the part that spools you turbo so I think it would definetly affect.
I know that is what spools your turbine but I was saying if it is a little leak and you are reaching full boost, you don't have to worry about it, right?
Old Jun 29, 2005 | 05:55 PM
grubiaco's Avatar
Kelspar is right you are running at about 6psi.
thanks again,
heath
Old Jun 29, 2005 | 06:05 PM
Kelspar's Avatar
One more thing; i cant ever seem to get past 4k rpm when im driving. this is obviously bad.
Old Jun 29, 2005 | 06:32 PM
ambystom01's Avatar
Could it be an ECU or fuel delivery problem?
Old Jun 29, 2005 | 06:54 PM
grubiaco's Avatar
I don't understand why you can't get past 4k.
Old Jun 29, 2005 | 07:01 PM
Kelspar's Avatar
Nor do i; it just gets really loud; i thought it might be exhaust but wouldnt that be loud all the time? At low rpms (before 3k spool) i dont hear anything but the filter sucking and @ 3 i hear the waste gate open and it just stays on; ive checked vaccum lines; none seem to be kinked for bent and they are all on.
Old Jun 29, 2005 | 07:30 PM
TURBOit's Avatar
wow, one problem after the other... well at 6 psi you are making and holding boost at about the right rpms... but the fact that you cant go past 4k...
Old Jun 29, 2005 | 07:36 PM
initialDRacer's Avatar
It's possible that oil is not feeding into the turbo...or an exhaust leak. One of my screws on the header went off and it was making a loud noise. So basically, the turbo is being held by just one screw! I couldn't drive the car past 4k rpms. I had midas check it out and they replaced the screw free of charge.
Old Jun 29, 2005 | 08:19 PM
Kelspar's Avatar
Thanks ill try that in the morning.
Old Jun 29, 2005 | 08:48 PM
Boeturbolancer's Avatar
you should take a bunch of pictures of all your fuel/vacuum connections as well as pics of your wastegate/header connections. Also start the car and check the wastegate... is it dumping air at idle? If it is you forgot the sealing ring inside the wastegate. Sometimes it falls out in the box or during install.
From your boost it seems like your doing ok with leaks so i don't think that there's a problem but it is something to check. If you can't go past 4k and it feels like its hesitating you are most likely super lean on fuel. That means fmu might be connected wrong/damaged or the fuel pump may not be working right.
Do you hear the fuel pump at idle? It should be really loud and whining. Give us the answers to these questions and post good pics of the things above. The more the better. Thanks,
Boe
Old Jun 29, 2005 | 10:26 PM
Kelspar's Avatar
Will get pics in the morn. As far as the pump goes; hell ya its loud, sounds like a leaf blower thats off in the distance. And yes it is hesitation. I can keep it back by accelerating slowly but i still cant get past 4k. Hope to have them up on here in the early am.
Old Jun 30, 2005 | 06:06 AM
blaze_125's Avatar
If I read him correctly, he can't go past 4k because his hears can't take the lound noise the car makes.
