Turbo Soon
The only reason you got a knock of 10-12 was from the changeover from closed loop to open loop and your ECU not being able to respond quick enough. It has nothing to do with the amount of boost you have. I guarantee you will see that knock again occasionally when you gun it. And sometimes you won't. It depends on how quick the ECU responds. The real knock you need to concern yourself with is up above 5000rpm that comes about after a knock count of 0.
Knock is premature detonation caused by the reaction mixture igniting too quickly. There are two general ways to prevent this, cool the mixture by running richer (which you're already doing) or retard the timing.
I do and I'm not sure if you can or not. I'm working on changing the settings for the ECU to changeover from closed loop to open loop sooner since the load comes on sooner than WOT now with boost. Our ECUs were not meant to see loads they are now at lower RPMs and less throttle.
hey guys,
so senate has helped me get my afrs to about 11 and now ive noticed my egt is getting rather hott. haha like i almost hit 1600. but im not getting any knock. i dont really wanna hit boost again at wot becuase im afraid of going kaboom. i have the BKR7E plugs. the stock number is 6097. any ideas out there?
Well that's not too bad then. Obviously you want to try and drop the temps as much as possible without losing power. Try adding a bit more fuel and see what that does for you. If it stays the same or worsens, then your gonna have to fudge with the timing a bit. Let me know how it goes.
update
i just got my car back from the shop. it only took them 10-11 hrs to put in the clutch and motormounts. haha but the good news was that they quoted me 4-6 hrs for the clutch install so they highest they could charge me was 6 hrs. not to bad if i have to say myself. you can def. tell theres a performance clutch in as well as the motor mounts cuz everything shakes. haha im still getting the "chatter" from my clutch. when i had the stock one in i could kindda hear it when i was at idel and not moving. now its a little louder, but i think i have to just give it some time, as well as break it in
ill keep yah updated.
how long you think it will take before i can start to get on it? 500 miles? cuz i plan on putting 300 on tonight because im heading home for a week
I had a clutch installed on my car and the chatter only lasted for about a few hundred miles. I actually stalled the car pulling out of the shop infrot of my dad and the mechanic. You could see my dad's embaresment as he shook his head. It was funny.
