My turbo build! Finaly!
get a SAFC,,,dont bother with the black box and the rrm will require you to get the 5th injector if u have a n '04+
And robbie, dude i dont know, i think it might just be quicker now...haha i dont know about on the street but on a highway pull its got some maad ***** now!! haha
if i where you i'd use ECU flash. its only $70 for the cable, and $25 for the datalogging software. You have an 02 so it'll be easy to get it running. Plus there are plenty of guys on here who can help you
I'm running emanage. rrm would be similar. they are both better then afc because you can control ignition timing. emanage can control bigger injectors, I'm not sure if rrm can do that.
New question:
Ok so finaly got it all working 99.9% , just gota put the glove box back in and stuff, but now it was boosting great and stuff, but randomly now, its happened twice, i get a check engine light. I dont have a scan tool, but the car seems to just as well as it did, idle it perfect, no smoke, no weird sounds...is it just because ive got no CAT's atm?? mayve that spacer thing on the downpipe is not really working?
I reset it the first tmie then it came back like hours later after bossting fun, then i drove aroudn wtih it on for a while, then just parked my car now and reset it again....
ideas? anyone have the same deal?
p.s.
got no cat's cause the downpipe eliminated it.....im going to install a 3 way cat when i get the cat back done though.
p.s.
Because you have no cats, your o2 sensor is reading bad air. Once you get a cat put in, make sure you have an o2 sensor bung put behind the cat so it reads cleaner air. You should be ok then.
