turbo sizes and performances?
Old Apr 12, 2008 | 06:55 AM
cantcatchme96's Avatar
Registered User
I have a t3 turbo right now, Im going to downgrade to get a faster spool time, should I go t25 t28 or tod4? is that smaller than a t28 not sure? which would give good spool time, decent top end for 10psi lancer? what would you all recommend?
Old Apr 12, 2008 | 08:23 AM
lancer2show's Avatar
16g and t28 is comparable. the mitsu turbos are cheaper than the garrets.
Old Apr 12, 2008 | 09:22 AM
SLVROZ_03's Avatar
Go to Garrett's site and check out the compressor maps to see what might be optimal for your setup.
Old Apr 12, 2008 | 10:04 AM
Registered User
i checked out some of garett but i think ima go mitsu again because the money factor, but what does everyone else have? i want the smallest turbo i can get for the best spooling however decent top end? im assuming t28 or tod4
Old Apr 12, 2008 | 10:12 AM
SLVROZ_03's Avatar
T28 sounds good.
Old Apr 13, 2008 | 01:59 AM
Registered User
is the tod4 smaller than than the t28? and bigger than the t 25??
Old Apr 13, 2008 | 02:15 AM
TheShortBus's Avatar
the 28 and 16g are fairly close, and you can a used 16g for cheap easy. only down side is making a manifold for it.
Old Apr 13, 2008 | 04:31 AM
what manifold are you running
Old Apr 13, 2008 | 07:19 AM
SLVROZ_03's Avatar
Just so you know, you don't have to get another manifold. Someone linked an adapter off of Ebay for a T3 to 16G on one of my Civic forums. I'm sure that'll raise an eyebrow!
Old Apr 13, 2008 | 02:21 PM
Registered User
i have a custom manifold i made, but whats the differences between the t28 and 16g or whats better? and no one knows much about the td04 turbos im guessing ??
Old Apr 13, 2008 | 02:39 PM
all i know is road race used to only use t28's and t25's then i think they started making a 16g kit after everyone started to swap everything out of evos. i doubt thats the real reason, but still Brian that works for road race runs a 16g over a t28. pluss id say that would be your best bet since SLVROZ 03 said he saw that adapter, so you dont have a make a hole new manifold
Old Apr 14, 2008 | 02:01 AM
Registered User
can anyone at least guess or maybe know the spooling times for these 3 turbos roughly, the t28, 16g, and td04...... I cant seem to find much information on any of them. Im actually leaning towards the t28 right now, but if the td04 is faster spooling and similiar to the others than Ill go with that? Any ideas thnks
Old Apr 14, 2008 | 06:54 AM
ambystom01's Avatar
You have to be more specific, there are different kinds of T-28s, 16Gs and TD04s. As an example, I have a TD04-13T and while it spools quickly (both in terms of boost threshold and turbo lag), the top end sucks and it runs out of steam above 20 PSI or so. Of the options though, I would go with a 16G since it's small enough to have quick response but large enough that it won't be a limiting factor if you want more.
Old Apr 14, 2008 | 08:53 AM
rabbit61319's Avatar
T28 will spool up pretty quickly, and it produces pretty good power.
If you are going for big power, T28 is not the choice.
It is kind of like the TD04, I was pushing 19psi on T28.
And it started to lose power at top end.
Old Apr 14, 2008 | 09:01 AM
ambystom01's Avatar
Well it's a trade-off, if you want a quick spooling turbo, you have to accept less top end power and vice versa.
