this is what happens when i get bored!
Old Nov 20, 2009 | 05:51 PM
  #301
JRR's Avatar
JRR
got some presents in the mail today!
manifold and 10.5 o2 housing came today
downpipe and seat will be here monday and tuesday.
replacing the studs in the 10.5, any idea on how to get them out without snapping them off? got them sitting in blaster rite now and gonna torch them tmw.
ill have pics up later tonite.
josh
Old Nov 21, 2009 | 12:39 AM
  #302
JRR's Avatar
JRR
here are some pics of the new setup. just need to do some welding on the manifold for bracing and add a pipe and a flange for my tial 38mm wastegate. going external dump with the wastegate, so it should sound mean i think. also gonna do some redneck porting on the hotside and manifold as well. just gonna clean up the flow a bit as well.
josh
Old Nov 21, 2009 | 01:11 AM
  #303
03lances's Avatar
Is that the speedcorps mani copy? If it is some things to note, you will have to elongate or just drill it out a little bigger the top passenger side mounting hole and the bottom drivers side cause the holes are a little off. Dont forget you will have to do a little grinding on the turbo to clear the waterpipe. Setup looks nice BTW
Old Nov 21, 2009 | 09:33 AM
  #304
JRR's Avatar
JRR
ya i got the mani from chele here on the forums. i was figurin on doin some work to it as well with bracing and my wastegate and all anyway.
josh
Old Nov 21, 2009 | 11:22 AM
  #305
*02Lancer*'s Avatar
Being that the manifold is a twin scroll were are you going to put the wastgate? Are you going to add a section between the turbo and manifold and put it there? And if you like the sound of external dump, why dont you just do with a divorced o2 Dump?
Old Nov 21, 2009 | 11:33 AM
  #306
03lances's Avatar
I am loving mine so far but still have a long ways to go, just did a pull in 3rd and laid it down in VDR and gave me 137whp and 160wtq, bone stock vdr gave me 89whp and 118wtq so getting better but not enough lol. Still at 5psi too though
Old Nov 21, 2009 | 12:10 PM
  #307
*02Lancer*'s Avatar
Nice sounds about right for 5 psi it's around 10 Hp per psi that you run on average. What is your next upgrade you plan on getting?
Old Nov 21, 2009 | 12:28 PM
  #308
03lances's Avatar
wouldnt mine getting a 501 maf and installing my evo 8 ecu. I think I wanna get a front strut bar for sure the es suspension blows lol
Old Nov 21, 2009 | 03:16 PM
  #309
JRR's Avatar
JRR
i could and prolly will but i got to weld the flapper shut so that i can use my external. and i figured that i had already spent $250 on a nice external that i didnt want to spend another $200 or so to get a stock looking one.
josh
Old Nov 21, 2009 | 08:35 PM
  #310
*02Lancer*'s Avatar
Yah i can understand that. So when do you want to have the 16g on the car?
Old Nov 21, 2009 | 08:49 PM
  #311
JRR's Avatar
JRR
well i got to get some flanges, pipe and some gaskets. then design time, and then to get the dsm 16g off. so i think im lookin mid december by time i get the time and money.
josh
Old Nov 23, 2009 | 09:56 AM
  #312
JRR's Avatar
JRR
update.....
got sommore presents today. the evo 8 dp showed up today as well as my new w/b sensor. so now hopefully it wont read a constant 14.7 afr and my fuel economy returns back to normal.
also anyone have any input on this....
best location for external wastegate?
josh
Old Nov 23, 2009 | 01:07 PM
  #313
03lances's Avatar
Hey I downloaded that dynostorm app for my phone and for the first run seems pretty accurate. Tested my wifes bone stock civic which is rated at 115hp, it has 188k miles on it and my phone rated it at 105 crank and 89 at the wheels, not too bad.
Old Nov 23, 2009 | 03:38 PM
  #314
JRR's Avatar
JRR
ya thats pretty accurate. same thing with pocket dyno for my ipod. it will atleast give you a "rough" number to work with/off before you actually dyno it to get an actual true number.
josh
Old Nov 26, 2009 | 09:40 PM
  #315
JRR's Avatar
JRR
well got the new w/b sensor in today and the car reads other than 14.7, whooda thought? found that when i got in my accident the sensor actually hit the rear cross member and dented the sensor which made it not work.
got my seat on tuesday, but i think the guy put a set of universal rails on it and the whole back of the seat is tweaked 20 degrees to the right! now the d-bag isnt answering my emails! figures
workin on getting the w/g flapper welded and the o2 bung into the evo dp. then its just a matter of a few gaskets and some fabricating and itll be ready to go in.
josh
and here is some of my latest work.....
runners will be going into solidworks this week
