Yet another thread about Turboing a 03 lancer.
Ok just thought I would update. I brought my maf scaling way up as I had previously dropped down alot trying to get my fuel trims in check. That along with raising my maf compensation I was able to get my open loop cold idle to a healthy 14.7-14.8. I still seem to have some erratic cold idle issues and seems the colder the ambient temp outside the more the idle trys to dip on me whether its cold idle or warm idle, although the idle is still eons better than it was before the timing change. Figured I might as well do some more fine tuning on the timing as well so I have been playing around with that alot lately, little improvements here and there. 3 steps forward 2 steps back seems to be a good description for tuning lol.
https://www.evolutionm.net/forums/7685255-post194.html
steven does have a good point but oddly enough I started noticing idle issues as well and NA no less. Sure it could and very possibly be tthe colder temperatures.
How long have you been running that boost level and orr how different is your tune from last winter.
I saw this beffore I lefft for worrk which I needed gas. Prices had dropped. I keptt thinking to myself is tthis screwing my scalings up considering in wintermonths gas goes down as there is more additives in fuel than full 89 or 93 octance especially in colder areas because gas will oxydize w/o heat so thus fuel companies put addditives in there and gallon for gallon there is less"gasoline" and more addittives in the winter.
May thats a cmplete hair bran idea but I see no reason why it couldnt throw off your precisely tuned scalings and you STFM ad LTFM readings...
In addition:
Throwing a 507 code (idle higgher than expected along with either fouled plugs or something up with my stock scalings or injectors going back (will check with evoscan in the morning) Its leading me to believe its foulded plugs as it has a tendency when the car is colder than warrmer. Have a "skip" sensation on accell and decel however code doesnt quite reflect that. HOPE ITS PLUGS!
In addition:
Thats the plan. Im a bit more concerned with the acel and decel throttle jumping. I dont see how the biss could be contributing factor with this and the idle is a bit high but not extreme. It cranks VERY low even with a brand new battery (had idle flucuation issues with a deep cycle battery that was going bad and did fix that problem). Low Im talking starting idle is estimated at 550-600 and slow increases as temps warm or switch to close loop. Will identify that as well while adjusting screw.
Was intending on buy new spark plugs (NGK) but went to the store and realized I had no driver side head light ($40) thanks auto dicks). Im not overly impressed with NGK and cannot understtand or justify 22 dollar spark plug (singular) that was specially laser cut? Has anyone experienced this. I typically (In past cars) gone with iridium $11/plug. Just thought I would share on here since the topics are fairly relevant to each other witth consideration of weather changing evoscan and ecu readings.
start on page one
"If someone has already said it, quote it and finish out strong" "Tools are like knowledge, the more you have the more you realize you dont have. :-P ''
Train if ya want to be a jedi haha jesus why cant I stop working on this...im flat out delerious and I have to work in 3 hours
Thats why I went with the Garrett T25. Spooling starts at around 2300rpm on mine. Havent heard of anyone using the shim in our rides. I believe 03 bought one but decided against using it.
was the t-25 what RRM used in their kits Grind3r? I long debated and bought more than one turbo before deciding to use the evo 8 turbo. I do know the t-25 mocks up well. did you run into many issues on the tuning side of things per ECUFlash or are you using alternate EMS? im waiting on fedex to shw up with my boost gauge and greddy oil adapter so currently bored at the presentt time
The started with a t25 so you could use there headers with it. Then they switched to the evo 3 16g knockoff....(long story) with a turbo mani. We are all on ecuflash/evo rom's
Hey have any of you guys bought the black depo headlightw with HID's pre-installed? I pulled mine out today because one light is dim compared to the other and so I was going to swap sides to confirm if it is the bulb causing the issue (hoping the dim light would now be on the opposite side) the only problem is I cant disconnect the bulb from the wire harness. I swear its one whole unit but wth good would that do. If anyone has these and had to replace a bulb lemme know what you did or if it just slide right out like its supposed to.
Read his thread.
kidding..
