testing turbo internals
Old Dec 10, 2003 | 02:18 PM
mark2002lancer's Avatar
how do you test the blade inside the compessor I had my set up a while now and i think ime hearing a rattle from the turbo on rev up and down
Old Dec 10, 2003 | 02:51 PM
any one
Old Dec 10, 2003 | 03:29 PM
bahamut's Avatar
This is pretty much the norm to take off the TC. Spin the fin. If the shaft wobbles, it needs a rebuild.
Old Dec 26, 2003 | 02:12 PM
the fan inside isent lose and feals nice but it still making a rattle noise an one have any sugg.
Old Dec 26, 2003 | 05:45 PM
TURBOit's Avatar
what turbo are you using, on the left it says 02 oz, but in your profile its a mirage :\ are you running a turbo kit that we know of, or is it custom built, i know it shouldn't apply really, but jsut wondering what size turbo you have and where you got and how long, i get a rattle, but its only on low end, and its just the turbo 'manifold' if you will tapping against my header
Old Dec 26, 2003 | 08:14 PM
tenkawa_akito's Avatar
it's probably a loose bolt somewhere on the exhaust. check all your connections along your exhaust
Old Dec 27, 2003 | 05:20 AM
JVlancer's Avatar
seems to me like exhaust.. mine did the same thing for a while till i tightened everything up then the noise went away..
Old Dec 27, 2003 | 12:04 PM
if a turbo is rattling, it's not gonna last long, and since there about 20 days between his two posts, I can only assume that the turbo isn't rattling. double check all the connections
Old Jan 4, 2004 | 01:31 PM
its a t28 the rrm kit I dont really drive that much I havent had much time to do anything but is not the exoust i just had it done and checked all the way down the line it only realy rattels an start up and then quits down and it does it on rev down and now the car revs real high on intial start up
Old Jan 4, 2004 | 05:10 PM
dans02's Avatar
to test for shaft play on the turbo you dont spin it...you take the intake side of the shaft and move it from side to side to see if there is excessive play.
Old Jan 6, 2004 | 04:01 PM
yea I sunn and tried to wiggle it sise to side seemed fine is that all i should be woried about thanks for all the posts Ive said before and ill probably say it again this site is the best out there
TommiM
Aug 19, 2014 04:54 PM
mikeywick821
Oct 23, 2011 11:49 PM
Project_Evo
Jun 7, 2009 04:09 PM
joon82
13
Jul 11, 2007 01:07 PM
AC556k
May 27, 2006 02:25 PM
