Oh Look another Turbo Thread - RyanCB's turn.
Old Aug 14, 2011 | 08:18 AM
  #91
The New Kid's Avatar
How long do you guys think it will take you to finish? Don't forget to take pictures so we can all see the build!
Old Aug 14, 2011 | 08:23 AM
  #92
ryancb's Avatar
Well next weekend is the motor. Then the following 03 have prior plans and hopefully the following we put the turbo in and start tuning. Thankfully between his rom and stevens it shouldnt be to bad to get a safe tune out of the box. I forgot to also mention I sent my 440's out friday to get cleaned and flow tested and the shop offers for an additional $5 an injector to mod them for me which turns them to 740cc injectors if i recall.
Old Aug 14, 2011 | 10:40 AM
  #93
03lances's Avatar
Im hoping for about 8-10 hours for the whole swap which I think is reasonable enough time to do this. I like to give myself 2-3x that amount of time to account for pretty much any problems we may run into.
Old Aug 14, 2011 | 11:31 PM
  #94
ryancb's Avatar
Just thought I would post some more pix of the oil pan and the intake mani i bought to port.
Looks like we will be starting this bright and early friday mornin now. Hopefully we will have it runing by night time and adjust any tuning sat.
Old Aug 14, 2011 | 11:47 PM
  #95
CrAnSwIcK's Avatar
FYI, RRM uses Evo 3 GT turbo's, it's a knock-off of an actual MHI Evo III Big 16G, spool is a bit laggier than the real Evo III 16g, from what i've heard, but it is basically identical to the real deal, and i have heard more good than bad about them, and the bad i have heard, seems to be a lot of regurgitated BS, i.e. friend of a friend's dad type thing. They can be purchased by themselves with actuators for around $330 new in box.
Old Aug 14, 2011 | 11:49 PM
  #96
ryancb's Avatar
You lost me there cran please explain more. The cheapest True Evo3Big16g i found was forcedperformance for 550 shipped. I wouldnt expect a real to be any cheaper. The 200-300 are usually the knock offs which at this point a couple hundred bucks isnt worth the risk to me or hassle of having to replace it in 20k
Old Aug 15, 2011 | 11:00 AM
  #97
jakermeister's Avatar
I love all the pics man! I'm gathering parts for my build right now. I just need the turbo, gauges, & couplers Keep posting the pics
Old Aug 15, 2011 | 12:02 PM
  #98
slatermvp's Avatar
what did you clean the IM with??
Old Aug 15, 2011 | 12:37 PM
  #99
burner67's Avatar
i think that you might run into a problem with that 45 degree return. at least i did..
Old Aug 15, 2011 | 12:39 PM
  #100
ryancb's Avatar
Details?
Old Aug 15, 2011 | 12:46 PM
  #101
burner67's Avatar
that low angle created a kink in my return hose. a lot had to do with that it stuck out further then where the lines would line up.
the return flange on the turbo itself was a lot closer to the block then i expected it to be.
Old Aug 15, 2011 | 12:47 PM
  #102
ryancb's Avatar
would you be willing to take a pic of yours and show me what you ended up doing?
Old Aug 15, 2011 | 01:33 PM
  #103
burner67's Avatar
well i dont have a jack at the moment but i ended up just using a 90 degree and it works way better.
heres a pic when i had the 45 degree tho. in this pic i had it cut because i couldnt even get the hoes to fit right on there. the 2 return pipes will end up being not very far apart.
https://www.evolutionm.net/forums/at...-13-23_769.jpg
Old Aug 15, 2011 | 01:44 PM
  #104
ryancb's Avatar
eek making me nervious...i think we might be ok since the RRM mani i think sits a little higher then the evos
Old Aug 15, 2011 | 01:52 PM
  #105
steven121's Avatar
Ryan hurry up we dont have all week we want to see this thing running!!! Lol
