Oh Look another Turbo Thread - RyanCB's turn.
Did you have to use all the shims on the flywheel? The stock one had 2 shims that go behind the f/w and one in the front. I notice there isn't one in the front when u installed the fidanza.
So you just bolted the fidanza flywheel right up to the crank with absolutely no shims? Not even one going behind the flywheel? Thanks I'm about to do this and just want to clarify guys.
Alright guys.... heres the 1st start up video. The noise seems to have smoothed out after driving a bit. I reset the ecu in the 2nd one it seems better to me but what do you guys think. I need to get some gas as im on empty and will log tomorrow. I loged on the way home from 03's place but that was 2hrs of driving so little much to post a log for you guys to look at. Anyways let me know.
1st Video
2nd Video
1st Video
2nd Video
yea i thought of that cause i need to go na for smog by the end of the month and was hoping he had a cap on it lol but i doubt there would be one that can work with hot oil but i guess im gonna need to remove my fitting
works fine so far.
