Oh Look another Turbo Thread - RyanCB's turn.
Old Sep 3, 2011 | 09:23 PM
  #211
Demon_ni2's Avatar
just remember u are learning alot in the process of doing all this.
Old Sep 3, 2011 | 09:37 PM
  #212
ryancb's Avatar
Thats for sure, I am way thankful for 03lances. It wouldnt have got this far without him. I am way disapointed with RRM if this kit is fine and how they norm ship it. Pipes seem pretty poor design. for location of stuff IE BOV ports. At this point I am trying to figure out where we should go. Im trying to find out if I could use the stock 9 ic with my current pipes as then it would put the IC much higher then where it is now. Right now i dont think I could honestly get the car out of my driveway with how low it is+ my coilovers.
Old Sep 3, 2011 | 10:14 PM
  #213
Demon_ni2's Avatar
ouch. ya i know sometimes with how peoples cars are setup, not all 'bolt on' setups will work because of reasons just like urs. evo parts will work, but the lower IC pipe depedningon on the location of the turbo may or may not work, might have to find some way to manipulate the pipe and or connections to better suite the car. i know a few of my connection pieces are really twisted around sometimes just for more clearance
Old Sep 4, 2011 | 12:04 AM
  #214
03lances's Avatar
I took measurements of ground cleareance with my IC and his. Mine was about 5" higher off the ground than his!!! and his coilovers are not really adding to that problem because my car is lowered as well and he has maybe a 1/2" lower drop in the front right now. Even if he could get out of his driveway which we both seriously doubt. One speed bump would destroy the IC . Ryan is not the only one learning alot from this build lol. Other than my manifold issue everything else was a piece of cake with the turbo portion of my install compared to this kit . Just the roll of the dice I guess we are so close to finishing but scheduling conflicts will put this build off until at least the week after next.
Old Sep 4, 2011 | 05:50 PM
  #215
HornstarBU's Avatar
My IC pipe would be higher, if I could get a better fitting Coolant Tank....stupid thing keeps my pipe from sitting up above the bottom of the bumper. Does yours get in the way, or...what? Better solution?
Old Sep 4, 2011 | 09:03 PM
  #216
Jogenmaru's Avatar
Wow. Ive been kinda gone for a long time. Glad to see another build happening. Even with the safety bar gone he still has intercooler clearance issues? Wow....how big of an intercooler does he have? It might be in the first post with all his parts. I sorta skimmed over that.
upon further investigation its the rrm big intercooler. Hope that goes well compared to what youve gone threw so far.
Old Sep 4, 2011 | 09:58 PM
  #217
03lances's Avatar
This ic is bolted to the bottom of the crashbar hence why its so low.
Old Sep 4, 2011 | 10:44 PM
  #218
ryancb's Avatar
well some small good news today, i found a coupler that will work for the intake pipe to the turbo so now just need the coupler for the intake pipe to the maf, finish extending my 02 sensors and mounting the 2nd o2 behind my high flow cat to keep it happy & the po po. Then figure out something with the IC. I want to cut the crash bar but I dont have the tools todo it so will need 03 or gotta go spend some more cash. Not really excited about the later at this point but if 03s schd wont work out for a couple weeks might need to. Thankfully the family has an extra car but no one likes driving it haha..Oh and get the damn downpipe extended and welded since the ***** cut it off instead of unbolting it.
Old Sep 5, 2011 | 12:50 AM
  #219
03lances's Avatar
I put in for the 17th off, going to talk to the boss to get a confirmation on that. Hopefully cutting that bar will raise the ic high enough for us.
Old Sep 5, 2011 | 01:00 AM
  #220
ryancb's Avatar
really man? Thats awesome, hopefully they can make your schd work so it doesnt screw up your stuff much at all. Yeah im hoping so. I really am tempted to pick up a evo9 fmic and see if the pipes will line up with the 45 bends. Seems easier and would cost about $130~. Cant decide. And cant sleep haha
Old Sep 5, 2011 | 01:01 AM
  #221
03lances's Avatar
Ill look under my hood tomorrow although not sure what you mean. Nothing hits my coolant overflow although my pipes hang real low too never tried to raise them up at all.
Old Sep 5, 2011 | 01:03 AM
  #222
03lances's Avatar
Did you measure the IC you have now? Basically if the outlets are roughly the same distance apart campared to the stock evo ic then it should work with the right couplers. There is some give in the piping.
Old Sep 5, 2011 | 01:07 AM
  #223
ryancb's Avatar
Let me go do that right now if your going to be up for a few more.
Old Sep 5, 2011 | 01:08 AM
  #224
03lances's Avatar
Always am lol. Remember im just getting off work
Old Sep 5, 2011 | 01:18 AM
  #225
ryancb's Avatar
Alright here are the rough measurements....
remember its kinda trapezoid shapped. Top is 19.5 bottom inlet to outlet is 25 in and height is 11.5
