Oh Look another Turbo Thread - RyanCB's turn.
Old Feb 4, 2012 | 10:19 AM
  #361
corndog17's Avatar
WPC MD309756 Water pump
WPC MD320174 Timing belt tensioner
WPC 372536 Camshaft seal
ROC TB119 Timing belt
Old Feb 4, 2012 | 10:22 AM
  #362
corndog17's Avatar
Keep it STD unless your refinishing the cranks bearing journals. All the clearances should be STD unless your machining the bearing journals.
Old Feb 4, 2012 | 10:30 AM
  #363
ryancb's Avatar
so std since told not to touch the crank on our car?
Old Feb 4, 2012 | 10:36 AM
  #364
corndog17's Avatar
Yeah... If there's no major scoring or grooves in the crank just polish that baby up and use STD size bearings. You can use plastigage to measure the clearances. Once you start putting it together. You should be good though no need to measure crush clearance if the journals are in good shape.
Old Feb 4, 2012 | 10:37 AM
  #365
ryancb's Avatar
thinking use my old motor which while old was fine
Old Feb 4, 2012 | 10:40 AM
  #366
corndog17's Avatar
The motor i rebuilt had 191k on it. The head over heated. All the bearings and journals looked mint when I tore it down. Your is probably in better shape since the coolant didnt mix with the oil and break down the oil.
Old Feb 4, 2012 | 08:11 PM
  #367
ryancb's Avatar
if i get the pistons .025 over do i need the bearings to be as well? Just thinking if getting block machined might be nice to be in fresh meat vs just cleaning it basiclly.
Old Feb 4, 2012 | 08:20 PM
  #368
corndog17's Avatar
yes machine it 20 over so that fresh crosshatch lines can be made into the cylinders and the new rings can seat good. oh my car almost passed smog today! damn idle air control valve code came up for high idle. Turns out my throttle cable was tweaked. had to reset the ECU and didnt have enough time to drive the car to update the monitors. Will give it another go on monday.
Old Feb 5, 2012 | 12:22 AM
  #369
ryancb's Avatar
Since we know you guys love carnage here is the video. I'm not sure why i didn't record it but 03lances camera did...this was first e85 pull. Not sure what tune looks like but guessing its close to same as pump gas tune. Running SD with 4bar MAP.
Old Feb 5, 2012 | 12:29 AM
  #370
ryancb's Avatar
I take that back i did record it...cutting it down and ill post in a few..
Old Feb 5, 2012 | 12:47 AM
  #371
ryancb's Avatar
Old Feb 6, 2012 | 05:57 PM
  #372
ryancb's Avatar
Does anyone remember Robert from Speedcorps customer cars page EvoM name or build thread?
Old Feb 6, 2012 | 07:57 PM
  #373
Demon_ni2's Avatar
so what was the final numbers before the 'pop' (bent rod im guessing)
looked like 230hp/270trq... thats nasty high power for a stock motor..
Old Feb 6, 2012 | 08:02 PM
  #374
ryancb's Avatar
Wasn't stock....that was zulus motor that was broken before went in from sounds of it...03lances has my car right now and might pull pan tonight to see if can tell what failed. K1 Rods Wes pistons but been making a tap noise since put it in, thought it was higher up since we first started it but looks like i was wrong. Do u recall roberts thread demon ?
Old Feb 6, 2012 | 08:23 PM
  #375
corndog17's Avatar
I guess zulu built a new block because he knew the one he sold steven had a problemo. no bueno. Did 03lance get the pan off it yet?
