Oh Look another Turbo Thread - RyanCB's turn.
better yet demon and I throw in $150ea you send each of us one and then we all have one
...sigh is it friday yet? picking up 30 gal of e85 today. Demon did you change anything to run e85 other then pump/injectors?
Alright guys lets start a parts list to build a motor. Contribute what you can part numbers cheapest price you have seen or paid.
I know demon, corn, and a few others have built theres or had it built someones gotta have a list.
huh? whatcha wanna know... i have a normal walbro pump (OEM filter on it) (walbro filter hates corn)
ummm.... thats really the only other requirement.. lol.. and bigger injectors.. im only seeing 65% duty cycle on my 1200s at 17psi with my big turbo.. but im suppose to be pushing more boost. just havent worked out the ecu bugs yet. car keeps breakin.. lol
acl rod bearings and acl main bearings(get them in a kit, will come with new thrust also)
pistons.. k1 work
rods.. whatever u can get for cheap, that are forged. 9.5:1 compression id just stick with. 10.5:1 will work also, as long as ur sticking to e85 or race gas.
arp toyota headstuds
arp evo 8/9 main studs
really about it..
pistons.. k1 work
really about it..
isn't there like 4 diff bearings for our motors depending on vin? Any chance you have arp p/n? English said never get our cranks resurfaced just find a used one not damaged.
Full gasket set - P/N ROC FGS1059
Oil pump - P/N ROC OP157
Crank Shaft Seal - SKF 33861
Spring, Timing - MD374578
Bolt cylinder - MD153368 (main bolts)
ACL rod, main, thrust bearings
http://www.ebay.com/itm/ACL-Race-Mai...item2c52595b42
How do i know if i want std or .025? Sorry guys i know i got a lot of reading todo but i need to make a decision quick if I'm going to borrow from the fan and just get it done right this time or go back to stock block for awhile.
