Oh Look another Turbo Thread - RyanCB's turn.
Old Aug 15, 2011 | 01:55 PM
  #106
ryancb's Avatar
Ha...Its a shame i dont have the replacement turbo yet...I have a feeling this swap will go pretty fast since got the oil pan sealed Just need to clean the head install the new cam shaft and put it all together. Then say a small prayer that it runs and doesnt knock for a week or two for 03's and my schd to line up again hopefully.
Old Aug 15, 2011 | 02:05 PM
  #107
03lances's Avatar
Originally Posted by slatermvp
what did you clean the IM with??
I have parts washer so I just turned it on and scrubbed the hell outta it lol.
Old Aug 15, 2011 | 03:11 PM
  #108
slatermvp's Avatar
gotcha. One last question: how did you take the pulley out that holds the timing belt. I'm trying to take the oil pump off the block but I can't take that pulley off. I'm almost ready to bag everything up and find a machine shop for the spare motor but I can't take that pulley off. PM me your email so I can send you a pic of what I'm talking about.
Old Aug 15, 2011 | 03:47 PM
  #109
HornstarBU's Avatar
The pulley that both belts link onto and the timing belt goes around? The crankshaft pulley I believe they call it. Only way to remove that is with an impact wrench. I had to actually put a glove on, and twist the impact socket opposite teh way it was loosening to get enough "umph" to get mine loose. (neat trick aye?)
Old Aug 15, 2011 | 03:53 PM
  #110
CrAnSwIcK's Avatar
Originally Posted by ryancb
You lost me there cran please explain more. The cheapest True Evo3Big16g i found was forcedperformance for 550 shipped. I wouldnt expect a real to be any cheaper. The 200-300 are usually the knock offs which at this point a couple hundred bucks isnt worth the risk to me or hassle of having to replace it in 20k
a few pages back someone mentioned something about an RRM 16G, i was just saying that they use an Evo 3 GT turbo, which IS by definition a knock-off.
Old Aug 15, 2011 | 03:54 PM
  #111
link62's Avatar
I think he means the sproket that the timing belt goes on that has the plate that spins for the crank sensor
Old Aug 15, 2011 | 04:53 PM
  #112
corndog17's Avatar
You can remove the crank pulley by putting a flat bar between the rod and block if the oil pans off and take a long breaker bar and some pebetrating oil break that ****er loose.
Old Aug 15, 2011 | 05:52 PM
  #113
slatermvp's Avatar
that's the one I mean.
Old Aug 15, 2011 | 06:10 PM
  #114
link62's Avatar
if i remember it should just slide right off might need a lil elbow grease lol
Old Aug 15, 2011 | 10:32 PM
  #115
03lances's Avatar
Yeah nothing holds it on but it nigh be a little stuck. You can tap lightly with a hammer and spray some penetrating fluid on the backside between the block and the gear then let it sit awhile to loosen up.
Old Aug 16, 2011 | 09:42 AM
  #116
ryancb's Avatar
New 50hp part showed up. haha
Old Aug 16, 2011 | 05:56 PM
  #117
Demon_ni2's Avatar
Omg omg...
Old Aug 16, 2011 | 05:57 PM
  #118
ryancb's Avatar
I think demon just had an O in my thread.
Old Aug 16, 2011 | 06:08 PM
  #119
Demon_ni2's Avatar
lol.. ur so silly
Old Aug 16, 2011 | 06:10 PM
  #120
ryancb's Avatar
Sometimes I try...ordered the new 16g, getting my 440s back tomorrow had them modified and cleaned/flow tested. Fuel pump will be here tomorrow as well. Ordered a SS line for the oil sender so its not directly on the block $20 insurance to prevent a posib acident.....
