Turbo sounds weird and loss of power.
Old Apr 22, 2004 | 02:46 PM
pgmike's Avatar
On sunday (also my bday) my ses light came on. I figured it was bc i out in the turbo and headers, but a few days ago i didnt have as much power as before. I watched the boost and it is still bosting just under 7psi. There is a weird sound coming from the turbo, it soudns like the fins are hitting something almost. Almost liek the sound of a baseball card being put in between the spoker of a bicycle wheel. This is maing me really nervous and so ive been keeping the rpms below 2k mostly. I do have an oil leak so im htinking it may be that there isnt enough oil running thru the turbo or something, but what do i know. Help me out.
Old Apr 22, 2004 | 02:54 PM
yellow_lancer's Avatar
you could have an exhaust leak at the wastegate...
Old Apr 22, 2004 | 02:57 PM
pgmike's Avatar
nah i dont think so. the soudns coming from the turbo and it would be a lot louder if it was coming from the wastegate id think.
Old Apr 22, 2004 | 03:01 PM
well the wastegate gasket that comes with the rrm kit sort of sucks... and from experience i can tell that anyone that did not replace it with like a metal gasket will eventually have an exhaust leak ... most likely going to lose power...
well worst case scenario... you blew your turbo... its hard to tell by your description...
Old Apr 22, 2004 | 03:02 PM
pgmike's Avatar
its still boosting so i donthtin kit would dtill boost and give some added power if it was blown would it?
Old Apr 22, 2004 | 03:17 PM
Typhoon Drifter's Avatar
I'd take off the turbo and make sure you don't have any small rock,nut's or screws lodged down in the turbine section.
Old Apr 22, 2004 | 03:30 PM
jamie's Avatar
when the wastegate was loose it was loseing power but it sounded like a bad leak but i don't think that is the problem.call boe at road race.
Old Apr 22, 2004 | 03:41 PM
IILANCERII02's Avatar
^^ i agree i would try hitting up RRM and asking them what they think could be up too
sorry dude, hope everything works out good
Old Apr 23, 2004 | 09:44 PM
pgmike's Avatar
sorry i havent been on since yesterday afternoon. i think ill call rrm tomo if they are open.
Old Apr 24, 2004 | 01:13 PM
Boni's Avatar
haha they deleted my post :/ ill say it again check the fuel pump/wastegate gasket/ or it may be the wastegate itself.
Old May 24, 2004 | 12:14 PM
mark2002lancer's Avatar
I have the same noise did you get any anwsers or any ideas i checked the wastegate gasket and fuelpump
Old May 24, 2004 | 10:56 PM
pgmike's Avatar
it was the oil leak so i tightened up the feed line and topped of the oil and it was fine after that. but then last week a bolt from my wastegate fell off while i was on a main road and i lost all power practically bc it was wide open. just got a new bolt and was fine.
Old May 24, 2004 | 11:24 PM
LancerO-Z's Avatar
It's definitely a good idea to get some grade 11.5 or so hex bolts and some good lock washers for your wastegate. Mine came loose twice, and I finally just changed out the bolts, no problems since.
Old May 25, 2004 | 04:31 AM
uh oh mike, i dont like to hear of probs. with that turbo haahahaha
Old May 25, 2004 | 05:50 PM
pgmike's Avatar
they arent really problems per se, its really jsut maintenance.
SuperchargedGTZ
78
Nov 15, 2009 07:21 AM
SpeedI2acerX
Mar 14, 2009 07:32 PM
Bdub25
11
Mar 20, 2008 05:11 PM
damen
28
Nov 10, 2007 01:59 PM
masterevo
10
Apr 23, 2004 06:17 PM
