stock speaker size
Old Apr 3, 2005 | 12:25 PM
ItsTheDriver13's Avatar
From: Danville, CA (it really is all about nor cal)
stock speaker size
does anybody know what the RMS and/or peak power of the lancer speakers are? a buddy gave me a set of speakers that are 6.5s that should fit in the rear, but i want to amke sure they aren't worse than stock. thanks
Old Apr 3, 2005 | 05:49 PM
anybody?
Old Apr 3, 2005 | 05:55 PM
camaro379ss's Avatar
i sont know for sure, but i'm sure the rms and peak are somewhat low since they are stock
Old Apr 4, 2005 | 08:33 AM
well duh. but these speakers arent that great. i just wanted to know if they are better or worse. i cant believe nobody knows the asnwer to this....
Old Apr 4, 2005 | 09:35 AM
wbresson's Avatar
If you'd wait more than a day you might get a response, patience is a virtue
Stock speakers in my Evo are labeled 15W 4-OHM on the back
Old Apr 4, 2005 | 10:21 AM
im in a lancer, thus why i posted in the lancer forum, not evo. thanks tho lol.
and i bump when its not on the top. this thread secton doesnt get browsed much, so things that arent on top rarely get seen. thanks tho fgor the suggestion.
Old Apr 4, 2005 | 03:06 PM
Sassmaster's Avatar
15W is about right, figure the HU is putting out 25 peak per channel, 15W RMS power handling on the speakers would be a good match for that.
anything is better than stock.. with certain exceptions such as pyramid, bose, jensen
(yes, I included bose, bose sounds like ***, if you think they don't, go listen to a REAL high end sound system)
Old Apr 4, 2005 | 04:31 PM
15 rms? what is peak? i have 120W to go in. im assuming these are better than stock. 15 W soudns really low though. my deck is pumping 50x4 through these guys.....and i havent blown anything yet. 15 W would be fine if they were like 1 ohm with indivudual amplieirs like a bose premium audio system that some cars have. 15 W sounds realyl low though.
Old Apr 4, 2005 | 05:42 PM
wbresson's Avatar
That HU is really probably putting out what 20W RMS ? Mine also says 50x4 but is maybe 20RMS, at about 3/4 volume the stock speakers distort very badly
Old Apr 5, 2005 | 12:48 PM
brentg07's Avatar
yea the speakers are 15W if I remember right. like the last post said 50 watts is the peak power comin out of ur h u, the rated rms watts are probably around 20, and depending on what brand that can be a little imbelished
Old Apr 5, 2005 | 12:49 PM
brentg07's Avatar
good luck finding peak ratings for the stocks by the way, call dealership maybe
Old Apr 5, 2005 | 12:50 PM
yep, just looked at my speakers this mornin cause i need to replace them and they also said 15w.
Old Apr 5, 2005 | 10:08 PM
thanks guys.
and my deck is pioneer and i can crank it to 5/6 power (50 out of 60 on the knob) and not get ANY distortion. Maybe ya'll should try balancing your sound. I havea sub, so i dont need bass through my speakers. when u remove the bass from the speakers in the built in EQ on a an aftermarket deck you can crank them much louder......
but im sure u guys know this.......
thanks. i will be replacing my speakers then i guess!
Lazer77
Lancer Troubleshooting
Mar 2, 2010 11:42 AM
joedr
Apr 11, 2007 10:50 AM
turtlelancer
Jul 26, 2004 05:39 PM
rouentahl
13
Nov 23, 2003 11:13 PM
steinvb12
Apr 3, 2003 12:01 AM
