amp install questions
Old Aug 26, 2005 | 08:54 AM
Ozdriver's Avatar
are there any grommetts *sp in the firewall that arnt being used that I can run my power wire through this is how I have done every other stereo install with my past cars.. the only thing I have found as far as how tos on the forum was to run the wire through the fender which I would rather not do anyone have any input that could help me out? I have searched but have found nothing that helped me out...... thanks guys
Old Aug 26, 2005 | 09:00 AM
Frozenrock's Avatar
Not that i found when i installed mine, you can either drill a new hole and grommet yourself or go out the door boot and through the fender
Old Aug 26, 2005 | 09:04 AM
wiretap's Avatar
There's one underneath where the glovebox is, and one next to your left knee on the drivers side next to the fuse box thingy that goes thru the fender.. it doesn't go "outside" the car though where it will get messed up or be visible, it does have a rubber grommet too. It can be ran from there right up under and come out near where the bottom of the windshield ends (but under the hood of course). I prefer the one under the glovebox; thats the one I use, and mostly everyone else does. The fender one is kind of a pain and hard to reach thru.
Next time use the search feature on the forums, this is been covered before.
Old Aug 26, 2005 | 09:19 AM
Ozdriver's Avatar
thanks guys
Old Aug 26, 2005 | 09:43 AM
blacklancerr's Avatar
i used the one under the glovebox. it was easy to get to.
Old Feb 23, 2006 | 04:52 PM
boomn29's Avatar
EDIT: I'm blind, the grommett is there on the Evo IX too. It's really awkward to poke it out through the firewall though. After that, no problems.
Old Feb 25, 2006 | 11:38 PM
ThunderOZ's Avatar
here maybe this will help...https://www.evolutionm.net/forums/sh...4&page=2&pp=15
Old Feb 26, 2006 | 02:10 PM
diamondstar03's Avatar
You can run the wire across the engine compartment although I would not do this if you are planning on powering an amplifier that will power the front speakers as it will be more likely to have engine noise. I ran 0awg through the inner fender well and then into the gromet @ the kick panel and it worked great. If you are just gonna use it for a subwoofer amplifier then you would probably never notice the noise if it is present.
xanderracing
24
Feb 14, 2024 12:14 PM
UOEVONO
Feb 10, 2014 02:09 PM
500evo
Mar 21, 2012 02:09 PM
Thoe99
Jul 16, 2007 06:37 AM
Evolutionken
May 6, 2005 10:29 PM
