can i put this in my car?
Old Apr 19, 2006 | 08:15 AM
kott_tot's Avatar
i found this little 6.5 inch sub and thought i could put it in my car? maybe a little sub box or something like that and bolt it behind the middle seat. Im not a big fan of taking my entire trunk for two 12, i just want a little more bass. i think its a goldwood.
Old Apr 19, 2006 | 08:21 AM
kott_tot's Avatar
Old Apr 19, 2006 | 08:32 AM
Danno's Avatar
Sure why wouldnt you be able to put it in?
Old Apr 19, 2006 | 08:34 AM
kott_tot's Avatar
im just wondering if i should take the time to make a small 6.5 inch box and if i could mount it behind the rear seat, or if this isnt a car speaker would it break faster, and what kind of box would i need, what size??
Old Apr 19, 2006 | 08:36 AM
evo4g63awd's Avatar
its your call, i wouldnt do it for that small of a sub, but it will add bass to what you are listening to...
Old Apr 19, 2006 | 08:38 AM
kott_tot's Avatar
cause i have new 6.5 inchers right now a they produce a surprising amount of bass, and this is definitely made for lower ranges, look at the sixe of that magnet. i dont thnk i could use it like a free air though, so id ahve to make a box,
Old Apr 19, 2006 | 09:30 AM
black03oz's Avatar
check into a JL 6W0. It is a true 6 1/2" subwoofer. I've been using one as a sub in the front of my car for a while now and I'm still shocked at it's performance. It will reproduce a solid 40 Hz and is still somewhat audible down to the 20 - 30 Hz range.
Old Apr 19, 2006 | 10:12 AM
kott_tot's Avatar
in the front? where did you put it?
Old Apr 19, 2006 | 12:49 PM
blaze_125's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=116048
Old Apr 19, 2006 | 01:35 PM
kott_tot's Avatar
wow thats a crazy place to install a sub
Old Apr 19, 2006 | 01:38 PM
kott_tot's Avatar
maybe i could stick a small box just above the rear struts, that front sub sounds like too much work, but in the trunk for such a small sub seems liek it would get drowned out, any more opinions?
Old Apr 19, 2006 | 02:52 PM
BillAce's Avatar
Subs are cheap. What is the impedance? Some home woofers will need larger ported boxes and waste space. Get a single 10" and a small amp and you will likely get better results wihtout spending much $$$$.
Old Apr 19, 2006 | 05:30 PM
Andrew LB's Avatar
Most home speakers are 8ohm and will not work properly in a car powered by an amplifier running @ 2 or 4ohm.
Old Apr 19, 2006 | 07:58 PM
kott_tot's Avatar
http://www.partsexpress.com/pe/showd...number=290-352
this is the closest i could find to it, i cannot find any label on the actual speaker
Old Apr 19, 2006 | 08:18 PM
black03oz's Avatar
here ya go...
http://cgi.ebay.com/JL-Audio-6W0-6-5...QQcmdZViewItem
