Speaker Recommendations
Old Dec 27, 2006 | 05:46 AM
cij911's Avatar
I am looking for a nice clean sound from an Alpine 9856. I primarily listen to Classic Rock, but also listen to Rap, Metal, Alternative, and Classical. At home I have Boston Acoustics in a 7.1 setup and like the sound a lot, so I have considered BA for the car.
Do you guys have recommendations for clean, smooth speakers run off the deck? Should I go with 6.5 comps front and coax rear? I would love a sub, but dont want to spend the money, add the weight, or lose the trunk space. I have been reading about CDT, eD, JL, and others, but would like to hear from you. Thanks
Old Dec 27, 2006 | 06:04 AM
Street Solutions Racing's Avatar
I have some mb quart components and rear coaxials for sale brand new 245.00 for the front and rear shipped.
Jaosn
Old Dec 27, 2006 | 12:21 PM
bene's Avatar
mb quart, kicker, eclipse .. theres alot of good brands
Old Dec 27, 2006 | 04:52 PM
Dem_z's Avatar
JL or Infinity.
Old Dec 28, 2006 | 09:38 AM
SLVROZ_03's Avatar
I'd assume you love your BS home entertain system and love it's sound quality... So why not their car speakers? They're awesome, but heavy on the price. But you can't go wrong with them or MB Quart.
Old Dec 28, 2006 | 11:21 AM
bene's Avatar
for car speakers, make sure you listen to others before u decide on one because home audio and car audio dont sound the same
Old Dec 28, 2006 | 12:46 PM
kott_tot's Avatar
Originally Posted by BillAce
Metal dome tweeters are more likely to be harsh on the pillar. I'm not sure if Quart stuff is the same since they went bankrupt and were bought by RF but get silk domes if possible.
Pillar mounted tweeters have certain higher frequencies amplified because of reflection off the glass and hard dash top. Speakers with metal domes usually have more output at the upper range of frequency response so this amplifies the effect. Highs can sound lispy, shrilland won't be balanced to the output of the mid. Think fingernails on a chalkboard.
I also do not recommend just adding tweeters to a set of mids. The passive crossover is designed for a set of speakers and matches the frequency response and level of a component set. It is a very important part of the performance and should be matched correctly to the system. This is why most "name brands" are only average, they put very little into the crossover design and don't optimize the crossover for each set. They build a single version for all component systems whether a 4,5.25 or 6.5" set.
just something to think about
Old Dec 29, 2006 | 05:21 AM
cij911's Avatar
OK so some good options -- thanks....
I think for now, I will install the deck with the stock speakers. If I feel like I need / want more then I will likely go with an AMP and separates up front and maybe a small sub in the trunk (leave the rears stock?)...
I have been considering eD separates (6000s V2) http://www.edesignaudio.com/edv2/pro...products_id=49
for $125 they appear to be a great deal -- has anyone heard these or thoughts on eD?
Also was thinking about their small SQ10 sub in a .3cu ft box http://www.edesignaudio.com/edv2/pro...roducts_id=106
Finally, recommendations on a good 4 channel amp -- fronts and bridged for sub that won't cost a ton (~$250 range) -- would eD be a good choice as well?
One last ask -- any recommended installation / fab shops in the NOVA area??? Thanks a ton!
Old Jan 15, 2007 | 02:38 PM
SemperPete's Avatar
I'm running BA 6.5's in my front doors, and rear deck, w/ a 12" BA Generator series in a sealed box in the trunk. I keep the amp (BA GT Series) set moderately, because i don't want a massive amount of bass, just a clean sound, and that setup sounds awesome. BA will cost more, but like they say, you get what you pay for...
Old Jan 16, 2007 | 09:12 PM
silverES's Avatar
I have Polk 6 1/2 separates in the front of my truck and polk 5x7's in the rear with a polk 10" sub all powered with a 2 MTX amps and it sounds great!! I have had infinity, they are too bright for me. same with kicker speakers, they are bright. MTX subs are good (depending on the model), but again, I am not a fan of the speakers.
anyway, I highly reccomend Polk Audio speakers
Old Jan 17, 2007 | 06:06 AM
Newfoundlancer's Avatar
I've heard nothing but good sounds from Alpine speakers, as well as Infinity. Alpine subs in particular I find amazing. If you can afford a full Alpine setup, I'd go with that. Secondly, I'd go with the Infinities. Thirdly would be Polk Audio.
Old Jan 17, 2007 | 09:50 AM
silverES's Avatar
I had Alpine type R speakers and subs in my old RSX. like newfoundlancer said, if you can afford it, its definitely worth it, but, in order to use the speakers to their potential, you have to amp them, and Type R subs hit so hard that they need a large amp to power them which also bumps the price.
PriusRepellent
Feb 7, 2016 06:54 PM
LayinLo
91
Mar 25, 2015 05:20 PM
police1211
Dec 30, 2009 05:29 PM
bluewaterDEMON
Lancer Troubleshooting
12
Aug 27, 2007 07:43 PM
Turbocake
13
Apr 12, 2004 08:23 PM
