weird sound after amp install.
Old Jan 6, 2008 | 05:28 PM
shinbumee's Avatar
i got my amp installed for 4 channels.
whenver i'm driving, there is this weird sound that hurts my ear.
I tried to find what that noise was but i could not.
can somebody help me with this? drives me crazy.
Old Jan 6, 2008 | 06:59 PM
SLVROZ_03's Avatar
We need more detail than just loud noise. Does the noise pitch increase with your rpms? Re-do your grounds and scrape off the paint before you screw into the metal.
Old Jan 6, 2008 | 07:41 PM
shinbumee's Avatar
not really, the sound does not increase with rpms but when i put into Drive, it makes some noise.
I'll try to scape off the paint and try it again.
Like, where exactly is the good spot for ground? solid metal?
Old Jan 6, 2008 | 10:34 PM
sly's Avatar
sly
yeah make sure ur ground is good or make sure your not having a loose connection somewhere.
Old Jan 6, 2008 | 10:47 PM
SpineDoc's Avatar
did you run the rca's next to the power wire? if so it would cause that type of problem.
Old Jan 6, 2008 | 11:09 PM
Evil9's Avatar
+1
did you run you power opposite of your RCA's?
you should, if you ran all you wires together you would get noise
alway run the power on the opposite of audio wires
Old Jan 6, 2008 | 11:15 PM
J Money's Avatar
if the amp is older that could also cause the problem..how old s the amp?
i'm using an older mtx 4 channel and it has a high pitch wine noise..kinda annpoying
Old Jan 7, 2008 | 09:39 AM
shinbumee's Avatar
Thank you.
I sanded the paints, separated the RCA cables away from the power wire.
not only the sound went away, there was this sound that came with rpms when a/c was on. That sound also went away.
Thanks
Old Jan 7, 2008 | 04:57 PM
SLVROZ_03's Avatar
Alright! Sound advice from some sound experts! Good luck
Atenza
May 26, 2016 03:31 AM
OhhBx
Jan 7, 2014 08:28 PM
pkieca086
Sep 13, 2011 02:50 PM
Bishonen SE
Apr 16, 2011 09:04 PM
camillejorge8
Feb 12, 2009 02:30 PM
