ROAD/RACE Piggyback VERSION 2
yeah unless you wanna start your own tuning business and get a bunch from them to tune yourself. thanks rock, really looking foward to having it back in.
Just got the piggy back today. Gonna be installing it again this afternoon
Can't wait. Now another quick question. Once I've learned the piggyback and dyno run it, then disconnect it for another pull - will I need to relearn the piggy again?
yeah, after you make a pull with it connected, just disconnect the red and white wires, then make your other pull, then when you reconnect it, I'm pretty sure you'll have to relearn it every time you disconnect it.
Originally Posted by 03RallyLancer
he will also probably have to disconnect his a/f wires from the box and reconnect them together... im not forsure, but the split second box probably wont let that signal through w/ no power
may need a little relearning... i suggest after the dyno just reset ecu and relearn all over again to be sure it's all good.
PLEASE... guys don't post about the technical if you really don't know. I've walked Z thru the process before but other conflicting info could be harmful. If you don't know for a fact it's better to just let the post go or pm someone who does know.
theyve said this already. the time it takes to get there, they said about 5 minutes to reflash, then the time to get back to your house, so theyve only got it for 1 day.
