ROAD/RACE Piggyback VERSION 2
Originally Posted by wudbevo
i installed my piggyback vs.2 yesterday morning. i filled up with a full tank of 93 octane before install! install was like 30 minutes saudered everything! have driven the car 80 miles, and idle has come back to normal only sometimes does it fluctuate. however, problem when i go to punch it, it jerks between gears like it isnt getting any fuel! dont know if this is normal, im thinking the ecu hasnt finished learning yet.
I think that this just may be a problem for us manual tranny 2002-03 Lancers - so I am just gonna go back to the original map - yes there was a little lumpy idle, and a little backfiring, but the increase in power from 2000-3000 and the solid performance after that is something that I want to have. I'll be giving RRM another call tomorrow.
good luck with that z
after some hardcore testing, at the track vs celica and others. i have found the gains dam near identical.
works great, no problems. and GREAT PERFORMANCE...now for rrm headers.
Originally Posted by Z_Lancer_Man
This is the same issue that I have been having - the jerking between gears. I've spoken with RRM about this so they are aware of it. You drive manual, which helps support our assumption that its something with the manuals. Akasirlancers testing as all been done on an automatic tranny. Assuming you drove it nice for ~30 miles at first, 80 miles is plenty to start opening it up.
^^ In all honesty, there isn't really an explanation why the jerking or "fuel cut" occurs. It has something to do with the settings that they are trying. All I know is that the jerking wasn't there with the original map/settings. I'll let ya know if I learn anything else.
Got off the phone with RRM we think they've got a solution. Pete is currently running the settings that the auto piggys will probably end up using and the settings for the manuals are being tested out this week. The manuals will probably have those done and fixed by Thursday. I just need to say that RRM is doing an awesome job getting this taken care of
The new settings being tested for the manuals are much better! After 70 miles, there is no CEL, no jerkines or hickup or pause when shifting hard and no backfiring. There is a rougher idle but its not as bad as the original map/settings. When idling at a stop, the idle may dip down to ~400 or so, or feel like the car will stall, but then it picks it self right back up and this dipping is pretty random and not too frequent. The power this thing makes is amazing. Quicker throttle response, when cruising at 80 MPH and you floor it, you actually start moving
, just a smoother stronger powerband. I'd say that they've figured it out. The rougher idle is a small price to pay for the performance you get
Good to hear they are working the bugs out cause i was planning on ordering one soon, i hope i get it with the latest and greatest updates so i dont have to go through the problems you guys have.
, just a smoother stronger powerband. I'd say that they've figured it out. The rougher idle is a small price to pay for the performance you get WADAD
