piggyback ecu connection?
my piggyback ecu will not connect to my laptop...well my laptop with the software and drivers....with serial cable usb - serial... then scantool...-OBD2 socket.... software says cannot connect...... hrmmm......idunno it says i might have wrong cable or check ecu...idk some help or sugestions...plzzz...
Are you talking about the RRM piggyback? if so, you do not connect to the cars OBDII port, you connect straight to the piggy, there are 4 screws on it, remove them, take the top off, and there will be a serial port in there. If its not the RRM piggy then disregard this post
rd122481
12
Jul 18, 2010 05:38 PM
