EcuFlash Definition File Master List
Old Feb 11, 2010 | 07:40 AM
  #166
nestoledo's Avatar
4g18
i need definition for a lancer 4g18 1.6L
Old Feb 11, 2010 | 04:18 PM
  #167
bluelancer20028's Avatar
tried 1.41 same thing but when i go to dl rom selecting 2001-2005 i get same message as trying to reflash but rom dl works with 2006 evo 9 selection
Old Feb 11, 2010 | 09:04 PM
  #168
senate6268's Avatar
The Evo IX ECU has a different ROM chip inside it. The '05 Lancer ECU might also have this different chip. I'm not sure what Openport cables the Evo IX guys use (1.3U, 1.3M or 2.0). This thread here will also help you with what version of EcuFlash to use depending on which cable you have: https://www.evolutionm.net/forums/ec...t-connect.html. You might need to use EcuFlash v1.3x.
Old Feb 13, 2010 | 10:47 AM
  #169
senate6268's Avatar
UPDATE... (02-13-2010)
Added definition file for 2002 OZ AT - 88560021. Extract to your rommetdata folder and choose "yes" when asked to overwrite files.
Old Mar 1, 2010 | 07:25 PM
  #170
finaly got everything working im using 1.42 to edit maps and latest evoscan to reflash
Old Mar 4, 2010 | 05:38 PM
  #171
ClixT's Avatar
hey guys, why is my values in ecuflash (x and y) are all messed up on my desktop computer?
its all fine from my laptop and they both have exactly the same version and latest definitions.
Old Mar 4, 2010 | 06:17 PM
  #172
senate6268's Avatar
The only thing that would change the x- and y-axis is the definition file. Is EcuFlash seeing your ROM as the same ROM ID on both your laptop and desktop?
Old Mar 4, 2010 | 06:26 PM
  #173
ClixT's Avatar
yup it is
btw, my rom id is 88540011
Old Mar 4, 2010 | 06:47 PM
  #174
senate6268's Avatar
yup it is
And you have the same definition file for 88540011 on each computer? And you are running the same version of EcuFlash? I don't think it'll make a difference, but are the user levels set the same in both?
Old Mar 4, 2010 | 07:05 PM
  #175
ClixT's Avatar
yes yes and yes. i just dled ur latest definition files and latest ecuflash.
i even reinstalled ecuflash on my desktop twice, same thing..
EDIT: pics added
Old Mar 4, 2010 | 07:26 PM
  #176
senate6268's Avatar
On your desktop make sure the endians are set correctly for RPM and load % scaling. Compare the endians between both your desktop and laptop. Having the same definition file should address this, but manually checking wouldn't hurt. I'm willing to bet that this is the issue, because if the scalings are all the same on both then I'm out of ideas.
Old Mar 4, 2010 | 07:50 PM
  #177
ClixT's Avatar
only thing i noticed is that the one on my laptop, the data endian is set to big. (All of em) and my desktop is little (some big)
got if fixed. =)
thnx senate for the help. i just made all of the endians big
Old Mar 12, 2010 | 04:05 AM
  #178
Lancerboi808's Avatar
hey man im new here EcuFlash where can i buy these
im think go for rrm piggyback but i seen these forums
let me know what to do
thanks
Old Mar 12, 2010 | 10:12 AM
  #179
03lances's Avatar
Ecuflash is free from openecu and the cable you can find on the FS forums here no problem.
Old Mar 12, 2010 | 02:32 PM
  #180
sorry i had to use this thread to ask ???
cause i need 50 post or something
but any way any1 selling the ecuflash cable? or where to get 1
thanks
