Lean under boost!!
Old Dec 4, 2008 | 04:59 PM
  #91
Complink's Avatar
are you manual or auto?
Old Dec 4, 2008 | 05:32 PM
  #92
4g94T's Avatar
auto
Old Dec 4, 2008 | 10:05 PM
  #93
sykou's Avatar
Just a question. Your running about 10 psi right. With the oem gasket also right. I might have blown my d ecomp gasket and all i got left is a oem one
Old Dec 4, 2008 | 10:39 PM
  #94
4g94T's Avatar
You blew the RPW decomp head gasket?
That thing is rated up to 15 PSI I think
I hope the stock one can withstand 10 PSI
Old Dec 5, 2008 | 01:36 AM
  #95
sykou's Avatar
ya the rpw one.... Im not too sure tho. Will be doing a comp test tomorrow tho to be sure.... I got none of the signs of a blown headgasket but I know another possibility could be that im blowing oil past the oil seal...
Old Dec 5, 2008 | 09:12 PM
  #96
4g94T's Avatar
I was just doing a pull and right when I would hit boost it would feel like I was hitting the rev limiter and lost of power. The check engine light came on and it was P0300 Random Cylinder Misfire.
I tried another pull and same thing =\
Anyone have any ideas?
Old Dec 5, 2008 | 09:23 PM
  #97
doctorjon's Avatar
Is the car feeling like its going to die at neutral?
Old Dec 5, 2008 | 09:39 PM
  #98
4g94T's Avatar
no it idles fine and drives fine.
Only during WOT...
I've never experienced this before. There's enough fuel, 0 counts of knock, idk what can be causing it?
Old Dec 5, 2008 | 10:30 PM
  #99
doctorjon's Avatar
Well signs of misfire usually lead to spark plugs and our coilpacks. Might be a Vac leak. Could also try checking your MAF.
Old Dec 5, 2008 | 10:40 PM
  #100
4g94T's Avatar
My spark plugs don't even have 1k miles.
They are ngk iridiums, forgot the part number
I'll check out the coilpacks, thanks
Old Dec 5, 2008 | 10:46 PM
  #101
doctorjon's Avatar
Yeah its just happening at full boost am i right? If its not your coilpacks than try checking your bov and how its being recirculated.
Old Dec 5, 2008 | 10:50 PM
  #102
4g94T's Avatar
Yup around full boost.
It's weird, because my car was fine earlier...
Old Dec 6, 2008 | 02:58 AM
  #103
sykou's Avatar
Hmmm hs it bogging out cuz its getting too much fuel? Snunds like it. Cuz same thing happens when i floor it when the rpms are too low... On another note, im trying to get my fuel trims in check but i can only manage to get a nice idle with stock latencies and stock injector scaling... If you dont mind, you think you could point me in the right direction which way you went with your adjustments?
Old Dec 6, 2008 | 10:08 AM
  #104
4g94T's Avatar
no, i know what it feels like when theres too much fuel, its different from what was happening last night.
what are your mid fuel trims?
if mid fuel trims > 0; lower scaling
if mid fuel trims < 0; raise scaling
Old Dec 6, 2008 | 10:40 AM
  #105
4g94T's Avatar
Okay now that it's day time I looked over my car and I noticed the tee for the BOV line blew off
