Lancer MAF Swap Step-by-Step Guide
Old Aug 12, 2009 | 11:49 PM
03lances's Avatar
Gotcha so the MAF is the same but the 9 has some different values thanks 4g94T!!
Old Oct 8, 2009 | 03:35 PM
Geronimo08's Avatar
Awsome thread, a must for sticky!
Edit: Thanks for the help. Great mod for the money.
Old Oct 26, 2009 | 04:43 PM
*02Lancer*'s Avatar
nvm
Old Dec 11, 2009 | 08:47 PM
*02Lancer*'s Avatar
Just got my 501 today thanks you senate for show's the how to and giving us the info again! Still want to get ahold of a dang evo ecu :P
Old Jan 31, 2010 | 06:45 PM
shinjinius's Avatar
i drive a 05 lancer es, 4g94, AT. custom headers and exhaust. SRI. it drives 'sluggish'. from what i can tell the 501 MAF swap sounds like its the solution to my problem and to get the most out the other 'upgrades'
Old Jan 31, 2010 | 06:48 PM
03lances's Avatar
Swap it out and also port match your intake manifold that will help
Old Jan 31, 2010 | 09:18 PM
shinjinius's Avatar
good deal. gonna order that stuff later tonight more than likely. how much would port matching cost me? or what would someone that knows to do that typically charge?
Old Apr 20, 2010 | 10:58 PM
02-Lancer-Es's Avatar
Anyone try and do the 399 Maf on a Non-turbo Lancer?
I want to try and run this one because there all over the place at a buddies shop and he is also known for tunning so i am wondering if he could do the swap for me .
Old Apr 28, 2010 | 10:51 AM
shinjinius's Avatar
i cant find the OBD-II port to plug the tactrix 1.3u on my 05 es. need help...
Old Apr 28, 2010 | 01:00 PM
link62's Avatar
look under ur steering wheel under the dash
Old Apr 28, 2010 | 08:42 PM
If you can find the port , dont find it and take it to get it done by a professional .
Old Apr 29, 2010 | 01:17 PM
shinjinius's Avatar
ok... now i need new map(.hex). where can i get it? heres my reading http://www.box.net/shared/j1j7yzk1ch
Old Apr 29, 2010 | 05:00 PM
03lances's Avatar
New map? I dont understand what your asking for? If you downloaded it correctly from your car you now have your stock map. Now you can modify it yourself
Old Apr 30, 2010 | 12:23 AM
shinjinius's Avatar
After i read the file from my ecu in EcuFlash and save it to my desktop as a .hex. Then i have to load the new .hex to write to the ecu, right? Or am i just going about this completely wrong?
Old Apr 30, 2010 | 07:33 AM
senate6268's Avatar
After you read your ROM from your ECU using EcuFlash you can save it or modify it. Then you would re-flash that modified ROM back into your ECU.
