lancer es fuel management question!!!
Old Nov 2, 2009 | 02:14 PM
steven121's Avatar
ok if the evo 8 ecu works for the lancer, do I need a fuel management system, I called road race and they said I needed a standalon system. I need help on just this part of turboing my car.
If i get the evo 8 ecu
440 cc injectors
will this be my fuel management system?
and do I need to replace the maf sensor on my car to make this work?
I have a TD05HR 16G 9.8 T turbo. Please help!!!
Old Nov 2, 2009 | 02:21 PM
TouringBubble's Avatar
Honestly, you don't even need the Evo VIII ecu. The Lancer ECU is tunable. But, the Evo VIII ECU is a better option as it is set up to handle boost. But to answer your question, yes, the Evo ECU is your fuel management.
If you use the Evo ECU, I believe it's recommended to use the matching Evo MAF.
Old Nov 2, 2009 | 03:15 PM
zulu989's Avatar
arent the mafs the same? thats what i heard
Old Nov 2, 2009 | 03:27 PM
ThunderOZ's Avatar
Nope, pretty different actually. The settings are very different between the lancer and lancer evo maf, not to mention the size. You would just need to change the settings in EcuFlash.
Here's a lancer maf, then the eclipse 501 maf, then the evo maf:
Old Nov 2, 2009 | 04:28 PM
steven121's Avatar
what size diffrence are we talking about? if i have the long ram intake system would the air filter i have still fit? or do i need to buy a new filter?
Old Nov 2, 2009 | 04:29 PM
steven121's Avatar
also will the plugs for the lancer and the evo be the same or do you need a new sensor plug
Old Nov 2, 2009 | 04:39 PM
ThunderOZ's Avatar
The plugs are the same, and fittings/adapters are as well. What do you mean what are the size differences? Look at the openings in the pictures...
The exterior dimensions are the same.
Old Nov 2, 2009 | 04:40 PM
ThunderOZ's Avatar
Unless your motor is seeing boost, I don't see a need for upgrading the maf like that...
Old Nov 2, 2009 | 05:27 PM
4g94T's Avatar
The size is not the only factor when considering upgrading your MAF,
it's the amount of air flow that it can meter.
Obviously, the Lancer maf can only meter so much at a certain point
and begins to lean out with higher boost levels.
Old Nov 3, 2009 | 12:44 PM
steven121's Avatar
my bad I thought you meant one was bigger than the other I was worried about installation issues
Sicktght311
Lancer Aftermarket Forced Induction Tech
42
Mar 30, 2018 01:13 AM
Alchem1st
Lancer Engine Management / Tuning Forums
Feb 6, 2017 11:29 PM
Nniikkooss
13
Jun 30, 2016 08:27 AM
evodziobak
Jan 26, 2016 04:24 AM
AutoMotoSports
Jun 16, 2006 01:39 PM
