Community Tephra Tweaking
Old Jan 28, 2011 | 08:39 PM
  #646
RoadSpike's Avatar
Originally Posted by Mitsu.kid.02
Yeah i logged 1byte load, do you see it in the latest log i posted? I did use the latest XML and ROM image, i clicked "Yes, to all" to overwrite the old XML
Crap the xml didn't save so they are fubared give me a minute i'll fix them up
Old Jan 28, 2011 | 08:42 PM
  #647
RoadSpike's Avatar
New XML with unfubared settings for one byte and knock light
File Type: zip
Old Jan 28, 2011 | 08:44 PM
  #648
Mitsu.kid.02's Avatar
Awesome! do you need another log?
Old Jan 28, 2011 | 08:45 PM
  #649
RoadSpike's Avatar
See my previous post about fixing Mut41 in the mut table.
I posted another rom you could just copy the mut table from it to yours now.
Old Jan 28, 2011 | 08:49 PM
  #650
ClixT's Avatar
Thanks! it's all fixed now.
Damn ur a god lol
  #651
Got it, all set everything shows up normal in ECUflash!
Old Jan 28, 2011 | 08:51 PM
  #652
So lancer auto rom now has the fixed startup, and big maps, and flash cel on knock, and load1byte, awesome!
Old Jan 28, 2011 | 08:52 PM
  #653
RoadSpike's Avatar
Got a log to verify the 1byte load numbers?
A knock light test is in order too
Oh guess i should mention the easy test for knock light is load set to 1 and knock sum set to 0. Should flash all the time that way.
Old Jan 28, 2011 | 09:00 PM
  #654
I need someone to test out the knock light, my CEL wont light up at all, i think the bulb is gone or is not sitting correctly. Getting a log of 1byte now, brb!
Old Jan 28, 2011 | 09:06 PM
  #655
Everything seems to be working fine with load1byte! Log:
File Type: zip
Old Jan 28, 2011 | 09:09 PM
  #656
RoadSpike's Avatar
Nice oh it may take knock sum of at least 1 to see the knock light working lets assume it works now.
All thats left is the mystery 6250 rpm timing cut out and that may be fixed with this version since so much code is changed.
Old Jan 28, 2011 | 09:12 PM
  #657
Yeah, so what was happening with that? I never understood fully about what was going on? Something about no being able to change the rev-limit? But im headin to bed guys, ill be on in the AM, its 12:13PM here in MA, and i need to be up at 6:15 in the mornin for work. Thanks spiker, the ROM is working great now! got alot fixed!
Old Jan 28, 2011 | 09:16 PM
  #658
RoadSpike's Avatar
Was a condition in the old rom that seemed to go wonky after 6200 rpm or so. Hopefully this major revamp fixes that issue as well.
Old Jan 28, 2011 | 09:36 PM
  #659
RoadSpike's Avatar
Originally Posted by link62
oh and road i think we should remove the old maps cause when i use maptracer it uses the old maps instead of the big ones
You should be able to select what map its using i know you can from the days i was doing some alt map tuning.
Old Jan 28, 2011 | 09:46 PM
  #660
link62's Avatar
ok cool got it know thanks
