Community Tephra Tweaking
Old Mar 15, 2011 | 04:17 PM
  #856
4g94T's Avatar
Thanks
Old Mar 15, 2011 | 11:55 PM
  #857
4g94T's Avatar
After a couple of miles, P0403 (EGR Flow Circuit Malfunction) showed up so I disabled it,
but it came back again. Did I miss something?
Old Mar 16, 2011 | 12:10 AM
  #858
RoadSpike's Avatar
Ah right the OBDII test set FCA periphery bit 9 to 0 it should be labled with EGR test or something.
Old Mar 16, 2011 | 12:14 AM
  #859
4g94T's Avatar
I just doubled checked it, its already set to 0
While searching the forums I found this:
Originally Posted by mrfred
ok, after some more disassem of the EGR routines, I have found that Periphery 0 (FAA) bit11 does not actually shut off the EGR system until the coolant temp passes ~68C. Its ok to use if you plan on ripping out all the EGR stuff. However, it turns out that there is a byte length value that completely disables the EGR system and is a better choice to use.
For USDM Evo 8 94170008-15 and EDM Evo 8 96530006 use:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="103D" type="1D" level="2" scaling="uint8"/>
For USDM Evo 8 96420007-11, 96940011, and USDM Evo 9 88590013-15 use:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="1041" type="1D" level="2" scaling="uint8"/>
A value of "0" disables the EGR system and sets the EGR duty to 0% all the time. "1" enables the EGR system.
Oct 4, 2009 - Fixed to show that the EDM Evo 8 96530006 address is 103D instead of 1041.
Old Mar 16, 2011 | 12:42 AM
  #860
RoadSpike's Avatar
I already gave you that address hmm..
I defined the egr tests right?
There should be one with a pressure difference volts for the map sensor. Set the pressure diff volts to 0 and I think it will go away.
Old Mar 16, 2011 | 07:08 AM
  #861
HornstarBU's Avatar
Cold takeoff problem
deleted
Old Mar 16, 2011 | 08:27 AM
  #862
4g94T's Avatar
Gotcha. Should I also set the EGR Map Check to 0?
Old Mar 16, 2011 | 09:06 AM
  #863
RoadSpike's Avatar
I have no idea what the map check does really so I would ignore that table for now. Use the pressure difference table for now and I can look at the others at a later time.
Old Mar 16, 2011 | 01:05 PM
  #864
4g94T's Avatar
Thanks RS, I'll try it out
Old Mar 16, 2011 | 04:04 PM
  #865
4g94T's Avatar
I set the voltage to 0 and P0403 came back after a couple of miles
Old Mar 16, 2011 | 04:26 PM
  #866
RoadSpike's Avatar
What are the values for the first four tables the ones with map volts?
Old Mar 16, 2011 | 05:12 PM
  #867
4g94T's Avatar
Map Test 1 = 0.10 Volts
Map Test 2 = 4.63 Volts
Map Test 3 = 4.22 Volts
Map Test 4 = 1.80 Volts
Old Mar 16, 2011 | 05:43 PM
  #868
RoadSpike's Avatar
Hmm lets set those to the infinite of bad see if it helps.
Set the tests 2 and 3 to 5 volts
Set tests 1 and 4 to 0.1 volts.
Old Mar 16, 2011 | 09:11 PM
  #869
RoadSpike's Avatar
IMPORTANT!
Do NOT try the jitter fixes I forgot to remove them from the xml :/ I'll correct them later and send a new xml but tonight I tired
Test Rom for SD
http://www.megaupload.com/?d=3LJ0R3RB
Requires my last xml which is in this thread somewhere I can link to it if needed ^^
Still looking at the 403 code
Edit:
Actually I'm gonna stop looking at it.
4g64 did you try the force ODBII inspection patch?
Old Mar 16, 2011 | 09:18 PM
  #870
link62's Avatar
IMPORTANT!
Test Rom for SD
Edit:
Boo my sd harness is still a few days away so hopefully this weekend I can give it a shot
