Roadspikes Huge Map Roms
Old Jun 25, 2013 | 12:14 AM
  #31
RoadSpike's Avatar
Air temp is actually selectable between both fuel temp and maf sensor. Its been awhile but i believe its setup to be fuel temp as a default? You'd have to look at the rom and see if the value is 0x3 or 0x5 both codes are written down to their meanings in the table.
Old Jun 25, 2013 | 05:21 AM
  #32
Live4Redline's Avatar
I looked for the option and didn't see it. I'll look again later this evening, thx.
Old Jun 25, 2013 | 05:25 AM
  #33
Green_Bandit's Avatar
Myself and another member are using fuel temperature. It's there.
Old Jun 25, 2013 | 05:54 AM
  #34
Grind3r's Avatar
Yep....Been running that way for over a year.
Old Jun 25, 2013 | 06:20 AM
  #35
No doubt, I just need to look again I guess. Thx
Old Jun 25, 2013 | 09:40 AM
  #36
RoadSpike's Avatar
I checked one this morning and it was setup to use the MAT sensor from the MAF. Its in the speed density programming section as SD Option: IAT
Old Sep 12, 2014 | 08:33 AM
  #37
ed_GST's Avatar
Bump this should be sticky
-Edwin
richardjh
Sep 17, 2023 01:02 AM
RoadSpike
Oct 23, 2016 10:41 AM
edesparza704
Lancer Engine Management / Tuning Forums
Sep 3, 2016 09:41 PM
DemiSlayer
Oct 17, 2014 05:25 PM
RoadSpike
Feb 5, 2011 12:27 AM
