Can I flash other Roms into My ECU
Old Jun 20, 2011 | 10:36 AM
infiniumz's Avatar
Hi. Wanna check whether is it possible for me to flash a different rom with different definition file
but using the same engine? Very eager to know or probably an Evo 8 Rom into my 4G18 1.6Manual 06 Lancer.
Old Jun 20, 2011 | 10:45 AM
03lances's Avatar
I know for sure I works with the 4G94. I have been running an evo rom in my Lancer ecu for over a year now with no issues
Old Jun 20, 2011 | 07:52 PM
ClixT's Avatar
^ I agree with him, but you live in Singapore and I'm not sure if the Lancer/Mirage/Evo ecus back there are the same.
Do more research to play it safe.
Old Jun 20, 2011 | 10:26 PM
ed_GST's Avatar
If the ready method is the same as the EVO rom your flashing and it uses two coils you can
Old Jun 20, 2011 | 10:51 PM
infiniumz's Avatar
Ok sure.. Thanks mates! So Is it possible to throw a jdm evo 8 rom in?
Old Jun 20, 2011 | 10:58 PM
infiniumz's Avatar
Hi ed_gst can you define what's ready rom? And which to coils? Meaning the ob2 cable?
Old Jun 21, 2011 | 11:29 AM
beto_gt's Avatar
ok, 4g18 engines are 1.6L, yes they have 2 coils. i think that you should purchase evo8 maf senson as in the 4g18 it uses map sensor, or you can make this through tephra. just suggestions, you should research a little bit more. i have a cs3 lancer too and i want to put boost in it!!!
Old Sep 14, 2020 | 08:45 PM
Rovin Raj's Avatar
anyone managed to flash other roms? most of the rom runs on MAF, i need a MAP running rom. i cant get a complete XML for 4g18
Old Sep 14, 2020 | 10:06 PM
RobGinSki's Avatar
You can but you still are probably going to have the change the values in the new ROM.
I have a Evo as my ROM but it was changed a lot to run my turbo and setup
Old Sep 20, 2020 | 11:52 PM
Rovin Raj's Avatar
are you running on MAP?
what rom did you use for your lancer? as many evo roms are 512kb type. Thanks in advance
Old Jun 17, 2021 | 01:54 AM
Rovin Raj's Avatar
you are running map sensor based rom?
plastus
Aug 4, 2015 07:59 PM
EvoCrazyyy
Dec 11, 2011 04:52 AM
Raptor58559
Mar 24, 2011 06:13 AM
grim~
Mar 27, 2010 05:47 PM
