starter issue?
Old Feb 14, 2015 | 06:51 AM
jb988's Avatar
starter issue?
Last night I parked my car went back outside to leave and I got in and turn the key and only here some.noises but no crank. Does anybody know where the starter is located on the 03 lancer es
Old Feb 14, 2015 | 08:47 AM
02modlanceroz's Avatar
Just follow wires off of your positive terminal. One of them should go to it.
Old Feb 14, 2015 | 09:48 AM
jb988's Avatar
Oh alright thank you.
Old Feb 14, 2015 | 01:02 PM
jb988's Avatar
I found the starter but the noise I'm hearing sounds like it's coming from this thing right underneath the throttle body, I'm not sure what it could be though. And ideas?
Old Feb 14, 2015 | 06:57 PM
jb988's Avatar
Looked at again and it turns out the starter is dead but I tried taking it off but could not remove one of the bolts for the ground cable for the starter. Any thoughts or advice?
Old Feb 15, 2015 | 01:33 PM
jb988's Avatar
Can't remove the ground bolt that holds the starter. Any tips
Old Feb 15, 2015 | 08:04 PM
Can you post a pic of it?
Old Feb 15, 2015 | 09:34 PM
jb988's Avatar
One of the only pictures I was able to sbap
Old Feb 16, 2015 | 09:43 AM
It's been so long since I have removed my alternator. I'd go take a look at it if it wasn't 1 degree outside lol. It's hard to tell from the pic what's going on. Is it just that tight, or you don't have room to turn a wrench? Can you get a socket on it, maybe swivel socket if you need? Or use a ratchet wrench. If it's too tight and you don't have much turning room. You could put another wrench onto that wrench to use as leverage.
ru4real
Jun 27, 2016 10:14 AM
nor11384
Feb 20, 2016 05:06 PM
Routybouty
Nov 25, 2010 04:13 AM
Darkn3s
Jan 4, 2010 12:31 PM
Methodical4u
Aug 17, 2008 11:55 AM
