Bigger injectors make a big diff?
Old Apr 5, 2006 | 03:43 PM
Handmemyarms's Avatar
I was curious to know if running bigger injectors on an N/A will make anything difference power efficency wise, and if so, what kind and where can i get em?
Im considering the fuel rail as my next small power mod but will injectors help along with this mod?
i ran a search but came up with nothing, its getting really hard to find things specific when running a search, but if someone wants to hook me up with a link to a thread that could help thad be great.
thanks in advance
matt
Old Apr 5, 2006 | 04:44 PM
twisty1251's Avatar
you're probably not taxing your fuel system enough with basic N/A mods for it to provide a gain.
Old Apr 5, 2006 | 07:01 PM
so not even a fuel rail would be effective?
Old Apr 5, 2006 | 07:04 PM
ambystom01's Avatar
A fuel rail will make the fuel delivery more consistent. It's really more of a support mod than anything else.
Old Apr 5, 2006 | 07:06 PM
senate6268's Avatar
Adding a fuel rail will ensure fuel is available for delivery under not so stock conditions. You won't need to change your injectors until you start raising your compression ratio by forced induction or high comp pistons.
Old Apr 5, 2006 | 08:51 PM
Blacksheepdj's Avatar
Fuel rail will not add power or efficiency, to answer your question.
It is a good support mod, so it'll give you the juice you need when you mash the gas (rather than the stock rail waiting to be filled up).
I had the rail, and I'd suggest it. But leave the stock injectors until you're maxing them out (or getting close).
Old Apr 5, 2006 | 08:58 PM
right on, thanks everyone
Old Apr 6, 2006 | 03:10 AM
rhyzin's Avatar
also note that larger injectors in conjunction with an AFC of some sort will lower power if the injectors are too big. to correct for larger injectors, the AFC will fool the ecu by lowering the measured intake of air, thereby lowering the amount of fuel sprayed into the engine. this in turn will retard ignition timing possibly putting it out of working range or decreasing power to where it's not even worth it.
Old Apr 6, 2006 | 04:44 PM
Tainted Winter's Avatar
I though our power cam from leaning the mixture out (i.e. PB). How could injectors help? it seems like they would bo your motor down. FI guy add them to compensate for the added air and keep a good mixture (to lean is what pops motors).
Old Apr 6, 2006 | 04:49 PM
ambystom01's Avatar
If you go all out NA and have really high compression pistons (like 11:1 or 12:1) I can see using bigger injectors along with a greddy emanage to keep the motor running fine.
Old Apr 7, 2006 | 10:55 AM
Go2fast's Avatar
Its really not going to be worth putting larger injectors in a stock compression lancer. ur going to encounter more pain in tuning and only get lil power out of it. You'll spend alot of money to get very little in return.
FL_SilverEvo8
31
Feb 11, 2016 03:45 PM
Gsxtremedsm
E85 / Ethanol
14
Jan 17, 2008 09:40 AM
KY
May 13, 2007 12:13 AM
dubbleugly01
Dec 23, 2006 01:52 PM
cpoevo
Jul 21, 2006 10:56 AM
