i dont think its hydrolock, what is it?
Old Jun 26, 2006 | 10:19 PM
03ozwhip's Avatar
i have an SRI and also a ViS Evo hood while i was in the car wash it died because of the water getting into the vents. i let it sit for a like 15 minutes and she finally started, but now with "CEL" am i screwed? i dont know a whole lot about engines but i know that "CEL" isnt good. any help would be good...
Old Jun 26, 2006 | 10:42 PM
03ozwhip's Avatar
cant anyone help me???
Old Jun 26, 2006 | 11:06 PM
Walkingchaos's Avatar
Its not hydro'd or she woudnt have started again that quickly. You probably sucked a little tiny bit of water into the MAF sensor and now youve thrown a code. Take it to autozone or something and have them pull the code to see what it means.
Old Jun 27, 2006 | 08:27 AM
Synthrocker's Avatar
Aye, doesent sound like hyrdo lock.
BEsides what walkingchaos said, you might of shorted a sensor. I'd go with the MAF though.
I know when I hydrolocked my Eagle Talon TSi it wouldent start- it would sputter and shot out water out the tail pipe accompied by some white smoke 8-)
BUT I did get it to run fine for a week till I sent the piston to the oil pan, so I'd suggest maybe doing a cylinder purge?
Shoot off fuel pump, disconnect coil packs, and remove spark plugs and crank about twice.
I know it may seem like over-doing, but better safe then sorry
I learned my lesson at 18 with my car =D Although, I'm starting to think it was crank walk haha When we took the block apart the crank was FUBAR
Old Jun 27, 2006 | 08:46 AM
Wallesasuaz's Avatar
disconnect the maf sensor wire... start the car, rev it a couple of times. Disconnect battery and let ECU reset. Connect batter, Connect MAF Sensor wire and then start car and let it re-learn again. Should work. I used to do this all the time and when I had a CAI.
it's not good, but it works.
Old Jun 27, 2006 | 11:53 AM
03ozwhip's Avatar
Today i started my car im not driving it but i started it, and the "CEL" wasnt on... does this mean i just flooded my distibutor?
Old Jun 27, 2006 | 12:07 PM
water probably just evaporated by itself... Ur good to go BOY!
Old Jun 27, 2006 | 12:32 PM
03ozwhip's Avatar
thank friggin god...
khalid.alghawas
Nov 26, 2017 07:32 AM
evohq
Feb 21, 2016 06:49 AM
Mooseknuckle
Oct 24, 2006 01:36 PM
lilman8403
Feb 7, 2005 05:12 PM
Evil_1
Mar 24, 2004 11:14 AM
