air filters
Old Sep 12, 2006 | 01:50 PM
  #31
Puerto_reCOn's Avatar
The K&N does fit, just gotta move a couple things. here's proof of my 06.
Old Sep 12, 2006 | 03:05 PM
  #32
lancerman360's Avatar
I wonder why k&n designed the pipe to cruve like that? I dont like it but it prob works well.
Old Sep 12, 2006 | 03:37 PM
  #33
mtags24's Avatar
[QUOTE=downsh!ft]
Originally Posted by downsh!ft
As for the filter the only thing that seems to be bad is the oil.. which the weapon-r doesn't look like it has (or may the article doesn't say ) . QUOTE]
it comes pre-oiled
as far as wet/dry and searching a few sites (long stories short)
dry good @ filtering out the smallest filters, but less air flow.
oiled cotten good @ air flow, not as good as filtering (to a point.) also the oil can become a mess if handed wrong (but how hard can it really be)
no offense but my advise is to not touch your car until you get educated on the subject. many people including me have made this mistake.
there is virtually no horse power difference between filters. the whole point of modifying a car is to make it better, so don't cheap out
Old Sep 12, 2006 | 03:42 PM
  #34
I thought the curve was funny too. but all in all, it's ok i guess. haha
Old Sep 12, 2006 | 04:56 PM
  #35
drucea's Avatar
yeah we know it fits the 06, he just said it wasn't carb legal. They have to approve for every year even if its exactly the same. I believe the curve is to get the filter up by the grill in direct airflow rather than back behind the battery.
Old Sep 12, 2006 | 05:05 PM
  #36
mitsuozboi's Avatar
Originally Posted by sdhes
according to AEM's testing, it is more efficient than K&N because K&N actualy need to get a little dirty in order to more effectively filter the air, that is partly what the oil, not grease, is for.
right...oil. There are probably comprable filters to K&N. Im not disputing that. On a lancer you are gonna make like what 2-4 hp? I think as long as you get a good filter that lasts its all good. I know K&N makes filters that last. I have no doubt AEM or some others make great filters but we arnt gonna make any more power I dont think. If that makes any sense.
I read RRm did tests on the stock hose and a smooth one like a AEM. The stock air hose was more efficient then the longer smooth pipes. Thats another reason I went with RRM's Ram air. Plus the CF heat shield is sexy.
Old Sep 12, 2006 | 06:27 PM
  #37
iFeLLdOwN's Avatar
Exactly. Just because the previous years were cleared doesn't guarentee the next year model will pass. As of this post, the 05 and 06 are not exempted yet, meaning it's illegal to have them installed. California cops can be a ***** about these matters so until k&n get the approval, I'm steering clear of the typhoon.
Old Sep 13, 2006 | 05:30 AM
  #38
downsh!ft's Avatar
Old Sep 13, 2006 | 05:45 AM
  #39
sdhes's Avatar
[QUOTE=downsh!ft]
it comes pre-oiled
I could be wrong, but I think all reputable filters come pre-oiled. You will still have to clean it eventually and re-oil the filter. I doubt the oil on the filter effects the engine or MAF sensor in any way, K&N says it doesn't, AEM says it does, or has in some cases. Who knows?
I've read that about the stock hose/tube that connects to the TB too. I recently took my AEM CAI off because it was rubbing on the fan motor and it started to develope a hole in the tube, It was for manual trans but I got it fit to my auto, I then made a DIY SRI from the MAF adapter of the CAI and the stock hose/tube I mentioned earlier, and used an AEM dry filter. the filter ends up, and fits nicely behind the battery. I also fabricated a bracket to attach the MAF housing to the strut tower, drivers side obviously, it looks alot like the damper that I bought which is on the other side, so they match.
iLLevo_
15
Mar 10, 2017 04:14 PM
mixlplix
Dec 10, 2012 02:59 PM
riksride
Jun 3, 2007 04:30 PM
livesports
Dec 16, 2005 05:24 PM
simevo
Mar 25, 2005 10:48 PM
