A2 Designs - Twin Throttle body
Old Sep 21, 2006 | 07:17 PM
  #46
army685's Avatar
i didnt know that 4g93 parts could fit our 4g94 engines? if it does fit then i will order the stage 2 as well! but i think ill wait for you elvis till you get your and install it i might order it in tha next couple weeks , i just bought a evo steering wheel, new racing seats, and got my trunk custom done with shaving the trunk lock , o yeah and bills! lol so im gonna have 2 wait. but keep me updated elvis
Old Sep 22, 2006 | 12:54 AM
  #47
mal_amor's Avatar
do these guys have a number or something
i want to get in contact with them but every time i send a email it tells me that there not going through....
i want to know if the stage 3 setup can be port and polished any further
and some one let me know: will safc be enough to make this work fine(as in i can still use my car for daily driver)
thank you
Old Sep 22, 2006 | 06:10 AM
  #48
gregivq's Avatar
You could probably polish stage 3 more but then the vacume pressure and heat will crack your intake manifold.
Old Sep 22, 2006 | 06:37 AM
  #49
Grey_Fox's Avatar
I had the same problem. You can e-mail him at chicomendes84@yahoo.com
Old Sep 22, 2006 | 06:48 AM
  #50
drucea's Avatar
I am planning to buy this october 1st when i get som emoney in. The twin TB that is. While I wait, i have questions.
Since its most likely for the 03 lancer, i have 04, what do I have to do to get the fuel rail to work? Can I just block off the fuel return line? Then everything else should just bolt up right?
Also, it says it comes with a FPR and gauge b/s/r, what gauge is that? and lastly, I have this feeling that i read somewhere that the 04s can't use the fpr, don't know why.
If I got these questions answered, and it works, I will gaurantee my purchase of these on october 1.
Old Sep 22, 2006 | 06:59 AM
  #51
HobieKopek's Avatar
The return is on the FPR, not the rail. Without ever having seen an '04's fuel rail I'm going to venture a guess that they're interchangable, if not identical.
Old Sep 22, 2006 | 11:09 AM
  #52
mal_amor's Avatar
so im still confused...does this setup still use the maf...or do i have to get a standalone ecu....any recomened brands for an automatic???
thanks
Old Sep 22, 2006 | 11:20 AM
  #53
crypto's Avatar
Former Vendor
auto, manual,. its the same, unless your running a CAI
this setup uses 1 pipe with the MAF attached, which then splits into 2 pipes
  #54
gregivq's Avatar
For best performance use Standalone.
To make it work, I guess you could still use MAF sensor.
Old Sep 22, 2006 | 11:22 AM
  #55
Shingen's Avatar
thanks
It uses the MAF so you are safe to use your stock ECU. The ECU will attempt to run at the same A/F ratio so you should be ok. To get the best out of this mod though you should really think about reflashing your ECU or running some kind of programable Piggy Back or SAFC...
I'm really eger to see what kinds of gains you guys get out of this. The price is right though and this looks to be a significant mod for us NA guys...
This is speculation but seeing as it uses the MAF and is a equal velocity stack you could turbo on this with a custom kit for even better results over stock IM.
Fox
Old Sep 22, 2006 | 11:49 AM
  #56
mal_amor's Avatar
does any one have a pic of the piping to the mani???
this sounds really strange and i would like to see it...
Old Sep 22, 2006 | 11:53 AM
  #57
crypto's Avatar
Former Vendor
go to the website and contact the guy who runs it.
Old Sep 22, 2006 | 12:10 PM
  #58
drucea's Avatar
he said he could get me pics of the piping by friday (today). I'll contact him again. And Shingen, you stole my idea about the turbo lol. I figured you could turbo it as well and I am planning on getting a custom setup made for it after i get the twin TBs.
Old Sep 22, 2006 | 12:15 PM
  #59
crypto's Avatar
Former Vendor
i already asked him about turbo as soon as i found out about it, this was his response:
It would be very easy to work with a turbo setup, as both throttle bodies are connected to one pipe which leads to the intake/mas. I could also weld the charge piping that connects air intakes instead of using silicone couplers such as on the n/a setups. I make quite a few of these setups for 1.5/1.8 mirages and I have just built 2 setups for the 2.0 lancer.
Old Sep 23, 2006 | 03:29 AM
  #60
mal_amor's Avatar
got some pics of stage 3!!!!
