How much would a evo engine
Old Oct 2, 2006 | 08:22 PM
  #46
HobieKopek's Avatar
Originally Posted by drucea
if you mean $6500 is the total of having it completely installed, then I'd say its really worth it. Cause a turbo only gets you a little more than the HP from an evo engine. And it costs about $5000. So you can then build on top of that rather than topping out your daily driver at maybe 300hp.
Honestly, how many people are really trying to build a more 300+ HP FWD tuner Lancer? If you're aiming for the stars and expense isn't your primary concern, by all means. Have fun. Otherwise...let pragmatism be your guide.
Old Oct 2, 2006 | 09:25 PM
  #47
lancerman360's Avatar
I am sick of this
Old Oct 2, 2006 | 11:16 PM
  #48
N1te's Avatar
Originally Posted by HobieKopek
It's amazing how after 5 years this topic still makes me want to punch people in the ****ing head.
0234, if you take the time to read up on engine swaps, and assuming you have half a brain in your head, I think you'd come to the realization that there is no such thing as a cost effective, much less, "drop-in" engine for the Lancer. If you want to play with engine swaps, buy a Honda. If you want to build your Lancer, be prepared to work with the 4g94 or pay out the anus for an impractical swap with little benefit over simply turbocharging your existing engine.
This is true. However, if he felt the compulsive need he could swap in the 4g64 from the Eclipse, build the block, and turbo that.
Old Oct 4, 2006 | 01:17 PM
  #49
mtags24's Avatar
Originally Posted by jdm4g63tgalant
yea, traction is an issue but fwd cars are not meant to be launched...from a roll it's a completely different story.
you say 300whp and fwd as a negative yet then you say just get a turbo kit?
why all the negativity? there's no reason to refurbish, rebuild, etc anything if you shop around carefully. i mean, it's not like you need a motor mount kit or anything it drops right in. and suspension, tires, etc are kind of a given i dont think many would try to run a swap with skinny tires on a 16 in rim.
like i said, the only real downfall is the cost of an engine right now (i would only deal with VIII or IX motors for the simple fact parts are easy to get) and if i had to pay somebody to do it i sure as hell wouldnt have even bothered.
yes you are right. i was just saying that if you slap an evo engine in a lancer and expect to have fun with the car it is going to break quickly. and turboing a 4g94 does not yield 300 hp without extensive mods along with the turbo.
i definitely see where you are coming from though, but in my opinion the completion of a swap still means you are a long ways off from yeilding the benefits of a swap due to other necessary mods. i was just making sure the starter of the thread was considering this
Leezon
Jan 29, 2013 11:21 AM
milruner
Oct 3, 2011 01:39 AM
tssang06
10
Aug 25, 2009 05:54 AM
Evo C.T.
Jul 18, 2009 07:23 AM
92lancerevo
Jan 30, 2008 08:52 PM
