pistons & ecu
Old Dec 4, 2006 | 12:05 PM
  #31
ambystom01's Avatar
You have 4G94 engine though don't you? You could always pick up an ECU from a wrecked lancer and have that flashed, including raising the rev limiter. Alternatively you could call WORKS and see if they could flash your current ECU, I would assume the two are pretty close code wise anyways.
Old Dec 4, 2006 | 01:21 PM
  #32
Mirage2.0's Avatar
I have 4g94 ecu and harness, but too much work. Is WORKS reflash more like RRM reflash or it's like adding afc to stock ecu?
Old Dec 4, 2006 | 02:18 PM
  #33
ambystom01's Avatar
The WORKS reflash is a custom reflash, they can raise the rev limiter, adjust timing, adjust AF ratios, whatever you want.
Old Dec 4, 2006 | 02:56 PM
  #34
Mirage2.0's Avatar
I'll call them tomorow. I actually just got '97 ecu. I'll ask if they can do something with it. If not I'll just put in '97 ecu which is already better than '98-'02. I'll keep it posted.
Old Dec 5, 2006 | 10:05 AM
  #35
gregivq's Avatar
How is it better?
Old Dec 5, 2006 | 08:20 PM
  #36
Mirage2.0's Avatar
The fuel map is alot better then '98-'02. And there is no fuel cut so I can go +140
I forgot to ask you: When you were changing pistons, did you change the rod bearings?
Old Dec 5, 2006 | 08:35 PM
  #37
ambystom01's Avatar
It has a higher rev limiter as well doesn't it?
Old Dec 5, 2006 | 08:39 PM
  #38
Mirage2.0's Avatar
Same 6800.
Old Dec 5, 2006 | 08:41 PM
  #39
ambystom01's Avatar
That's higher than my rev limiter, mine is at like 6000 or a little above.
Live4Redline
Lancer Engine Tech
19
Jan 9, 2017 09:55 PM
zeft12
Apr 13, 2013 02:08 AM
Mirage2.0
Lancer-Mirage Compatibility Forum
Apr 9, 2008 01:57 PM
Geo_lancer
Lancer Engine Tech
11
Nov 30, 2007 07:11 PM
mtags24
Lancer Engine Tech
67
Mar 23, 2007 08:00 PM
