Torque Specs for Head
Old Mar 5, 2007 | 07:56 AM
mvarcola's Avatar
Long story short, timing belt broke, have replaced everything. Got the car all back together torqued everything per specs, head leaks oil down the back of the engine. Can some please verify that I have the correct specs.
1. 54lb torque in the correct sequence
2. Losten all bolts back up
3. Tighten to 15# in sequence
4. Mark bolts with paint
5. Turn all bolts 90 degrees in sequence
6. Turn all botls another 90 degrees in sequence so marks line up.
This is what I got from the manual. This is an 2002 Lancer OZ Rally. Like I said above, the timing belt broke and I replaced the whole top end. Cars runs great just leaking some oil down the back. Not coming from the valve cover. I will check tonight to see if there is any compression issues.
Old Mar 5, 2007 | 09:41 AM
SLVROZ_03's Avatar
Did you have the head milled to ensure a flat/level mounting surface?
Old Mar 5, 2007 | 09:47 AM
mvarcola's Avatar
Yes, I had it completely redone.
Old Mar 5, 2007 | 03:34 PM
Blacksheepdj's Avatar
From AllData:
Old Mar 5, 2007 | 06:03 PM
mvarcola's Avatar
Yeah that is the way it was done. Still leaking, strange they did not just torque to a certain spec. Well I guess off with thw new head gasket and try it again!!! THANKS
sabastian458
43
Nov 2, 2015 01:35 PM
Auger
May 4, 2015 09:19 PM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
15
Dec 14, 2010 03:49 AM
Tuner@Swift
Aug 6, 2008 05:38 PM
turboDan
Apr 12, 2004 10:54 PM
