Stage 3 cam
Old May 6, 2007 | 07:14 PM
imalancerman's Avatar
Stage 3 cam
What are the downsides to a stage 3 cam? like I understand rough idle, ecu, valve clearance, and the addition of an expensive cam gear, but does it do anything to the acceleration? I was told that it would basically make my car slow until high rpms. Mind you this would be on a car with necessary modifications. Stage 3 turbo, pistons and rods, clutch, valve springs, etc.
Old May 6, 2007 | 07:17 PM
ambystom01's Avatar
All the things you said. There's a reason why RPW doesn't recommend you go above a stage 2 on a street car. Call be crazy but when a vendor tells you not to buy their product, it's for a damn good reason.
Old May 6, 2007 | 07:31 PM
Mirage2.0's Avatar
I'm running 272 duration and .436 lift crower cam.
Idle is perfect, no clearence issues. None of that.
Want to learn more, than hit mirage forums.
Old May 6, 2007 | 08:26 PM
iufan4lifeul's Avatar
With anything over RRM's cams (basically stage 2 and up) it requires cam gear, valve springs etc. a tune, and you get a bad idle and maybe a little loss of low end power. Stage 3 cams are worthless unless you are pushing major horsepower. My friend has 272 cams on a 92 MR2 and that thing is ROWDY but idles that a muscle car. And can beat out Evo's ALL day long I might add.
Old May 7, 2007 | 06:15 AM
Mirage2.0's Avatar
Believe it or not. I got the springs, 11.0:1 ROSS pistons, and other crap. TOP END is crazy nice.
Old May 7, 2007 | 07:17 AM
ya, if you beef up the motor and then run big cams top end COULD feel turbo'ish.
Old May 7, 2007 | 07:23 AM
Mirage2.0's Avatar
I'll be going to the dyno again soon. I'm picking my car today with me flywheel and PG. Still oem clutch, lol.
Old May 7, 2007 | 07:28 AM
ambystom01's Avatar
Pg?
Old May 7, 2007 | 07:58 AM
Mirage2.0's Avatar
phantom grip
Old May 7, 2007 | 08:45 AM
kungfugirl's Avatar
I would still own the crap out of any na lancer.
Old May 7, 2007 | 08:48 AM
Kurt's Avatar
Originally Posted by Mirage2.0
phantom grip
Why use Phantom Grip? Why not invest in a real LSD?
Do you really need a stage 3 cam in a street car?
Old May 7, 2007 | 08:55 AM
ambystom01's Avatar
I think a cam would be better compared to VTEC or something along those lines. Even with all the NA mods out there an NA lancer wouldn't stand a chance against a turboed lancer.
Old May 7, 2007 | 09:29 AM
Mirage2.0's Avatar
I have 4g94 in mirage. I'm trying to get down to 2100 pounds.
What about mirage from PR. Running 12.9 on street tires.
Old May 7, 2007 | 09:42 AM
Mirage2.0's Avatar
http://www.youtube.com/watch?v=55jlKuYwJ0E
Old May 7, 2007 | 09:52 AM
ambystom01's Avatar
How often do they blow their motors? PR is like Australia, they're in a world of their own when it comes to cars.
