P&P head and intake
Old Nov 20, 2008 | 09:02 AM
Racer24x's Avatar
P&P head and intake
Is it a good idea to port and polish an intake or cylinder head (w/o Flow bench), for the 'do-it-yourselfers or to just let a machinst do it?
opinions please
Old Nov 20, 2008 | 11:02 PM
sykou's Avatar
most people dot recommend it for the same reasons you stated(no flow bench) but it is the general idea that larger on the exhaust side does not hurt anything. Only thing you gotta worry bout is the intake side. If anything i would do what I did and port the intake side a little bit, and the exhaust side a bit more.
Old Nov 24, 2008 | 01:17 PM
Racer24x's Avatar
did you do it yourself and how if so?
Old Nov 24, 2008 | 08:25 PM
llt-racing's Avatar
You can do the basic stuff, largen the intake ports and match up to intake manifold, leave with rough abrassive finish. And you can polish the exhaust ports untill you get a mirror finish to prevent carbon deposits with in the port.
Valve ange job, shaving you can leave with your machinist.
Old Nov 24, 2008 | 08:49 PM
Evo666's Avatar
I did a valve angle job, port polished head matched to ported intake mani. None bench flowed.
Gain about 5whp on a Mustang dyno and about 10 after SAFC adjustments.
Old Nov 24, 2008 | 11:57 PM
sykou's Avatar
ya just used a grinding attachment to do the rough cutting and then a sanding wheel to finish it off. Like was mentioned above, leave the intake rough and go nuts with the exhaust side....
Old Nov 25, 2008 | 03:07 PM
Racer24x's Avatar
cool, so could i use a dremmel? or is there a better tool out there?
Old Nov 25, 2008 | 03:46 PM
ambystom01's Avatar
I would get it done professionally, you can actually lose power if you don't do it right.
Old Jan 1, 2009 | 10:26 AM
smartidiot2122's Avatar
another way to do it i heard off an audi forum is you can run your car and suck sand in the intake, that way the intake side and the exhaust are both ported the same.
Old Jan 1, 2009 | 01:02 PM
ambystom01's Avatar
And then you blow your motor, please don't spread internet BS on the forum.
Old Jan 1, 2009 | 01:15 PM
senate6268's Avatar
Wow...
Just wow...
Be sure to suck water in the intake after you're done with the sand to cool everything off...
Old Jan 1, 2009 | 01:28 PM
Speed Corps's Avatar
Former Vendor
I'd say go for it. Gasket matching will be good, just don't try and do a full race port. Stay away fromt the valves and valve guide areas. A dremel can be used, but will take alot longer than using a die grinder. If you use a die grinder, be carefull not to remove too much material by accident. Always keep the wheel moving. If you make any dips or pits, it will require you to remove more material just to smooth it out. There's alot of companies that sell porting kits that have all the grinding wheels and accessories you need. Just take your time.
Old Jan 1, 2009 | 09:43 PM
Green_Bandit's Avatar
Dude... WOW. I hope you were just playing.
Old Jan 2, 2009 | 05:34 AM
Jehuty's Avatar
No no, he was serious....
his car must be fast
Old Jan 2, 2009 | 06:35 AM
crypto's Avatar
Former Vendor
lol i remember that thread
for cereal though....
Port matching is easy and you can do that yourself with a dremel.
Everything else is best left to a shop. However if your gonna have a shop do the important stuff, you might as well let them port match it too
TurboKushGS-T
Lancer Troubleshooting
Apr 9, 2015 08:31 PM
JohnBradley
18
Jul 9, 2013 11:14 AM
biggie5252
Apr 3, 2010 01:15 PM
levo2nr
12
May 25, 2006 05:49 AM
Alchemist
20
Oct 13, 2005 02:08 AM
