Weight loss
Old Apr 22, 2010 | 02:51 PM
  #31
02-Lancer-Es's Avatar
The lip kit weights about 50-60 Lbs . That inlcudes Front lip , side skirts and rear wing . Also take the wing off it it has one and you woul deven loose more . Take the Rear sway bar off and go with coilovers . In what i just said i would easy see a 120 Lbs in weight lost .
Old Apr 23, 2010 | 11:58 AM
  #32
*02Lancer*'s Avatar
fill it with helium lol this isnt the grandsport corvette lol. and i will have to look into coil overovers for the rear. Thats for the idea going to be getting some aluminum bolts also in the near future to help a little.
Old Apr 23, 2010 | 03:50 PM
  #33
ambystom01's Avatar
120 lbs from just the lip kit and wing? That seems hellishly high to me.
Old Apr 23, 2010 | 05:18 PM
  #34
senate6268's Avatar
His estimate of 120lbs also included switching to coilovers and removing the rear sway bar along with the lip kit and wing. Regardless, 120lbs still seems a bit on the high side for all that...
Old Apr 23, 2010 | 05:20 PM
  #35
ambystom01's Avatar
Yeah, unless the lip and side skirts are made of solid steel, I don't see 120 lbs coming from those mods.
Old Apr 23, 2010 | 05:49 PM
  #36
lncrphish's Avatar
remove the vibration dampers behind your front bumper. get a carbon fiber hood too.
Old Apr 23, 2010 | 05:50 PM
  #37
ambystom01's Avatar
How much does the hood drop, 10ish lbs?
Old Apr 23, 2010 | 05:57 PM
  #38
lncrphish's Avatar
probly close to 20. i just moved mine from the garage to the shed and it was one heavy bit*h.
Old May 5, 2010 | 07:08 PM
  #39
diyrevo's Avatar
coilovers will really make a difference in weight, and lol@ loosing weight yourself.
Old May 12, 2010 | 10:02 AM
  #40
*02Lancer*'s Avatar
i got the car weighted in the other week. With me in it and just under a half a tank of gas it weight an even 2,500. Pounds according the scale at the track.
Old May 12, 2010 | 10:50 AM
  #41
Demon_ni2's Avatar
Cool. might have to get drastic if u wanna see it get any lower then that..
Evos Can get down to 2300-2400lbs (fully, fully, fully gutted down)
I gutted my doors, but left the mounting points so i could leave the covers on(covers might not stay for long)
CF truck, CFhood are the easy (but expensive upgrades)
fully gutted interrior, no dash, angle grinded off a few big brackets that actually weighed a ton..
without the turbo kit on my car, or my fat but, car weighed in just under 2k.. but its not exactly a street safe car.. LOL.. goal is 1800.. i got a few things to do still..
-5 gallon fuel cell is still at the top of my list.. and a full underbody tray
Oh, and the seats weight
factory driver seat (48lbs)
factory passenger seat (36lbs)
rear seat cushion (4lbs)
rear back support with bars attached(the 60/40 seat) (28lbs)
brackets for the seats, about another 15-20lbs..
Carpet (44lbs)
sound deadener (45lbs) (give or take 5 lbs, was hard to weigh)
Crash beams, and chacoal box, from the rear, about 40lbs.
Factory fuel cell, weighs alot actually, little under 100lbs from what i was told from an evo owner(without any gas in it)
i dont see a reason in removing the rear sway bar unless ur 100% drag only. but with that inmind.. Most drag hondas remove the front sway bar, NOT the rear. (i use alot of stuff from what i find on other FWD cars and try to apply it the lancer as much as possible)
coilovers will save a few lbs, and also help with setting ur ride height properly, u defiantelly want to look into a stiffer rear springs for the coilovers so u dont have near as much weight transferroff the front tires..
If ur wanting to drop ur Times more for drag racing, go ahead and get u some 15x8 rims, and some 22x8 or 24.5x8 slicks for the track, that will make the BIGGEST different, shaved almost .9tenths off my time, and made my 300' times much more consistant.
about all i can think of as of right now..
My goal is to see 2k-2100 with my fat butt in the car. (im a heafty 280)
Old May 12, 2010 | 08:32 PM
  #42
*02Lancer*'s Avatar
Nice i just swapped to some 17x7 that i got for real cheap. So im going to see how they do they weigh a little bit more but the sidewall is not flexing so i think i will have a better 60' idk i need to get a set of 15 with some slicks. i want 13's with this engine before it goes. and with all the work you have in your car i think you will be able to get it there. The weight you want that's including the cage that you WILL need correcr?
Old Jun 8, 2010 | 11:25 AM
  #43
japordie's Avatar
carbon fiber hood trunk and side mirrors, you can also get light weight strut towers. along with the light weight wheels and tires like said before by amby. I have a front strut bar and a lower tie bar which is lighter that teh rrm ones. lmk
Dragking2189
Oct 24, 2016 02:41 PM
mazda8799
Sep 25, 2009 08:33 PM
TrinaBabe
88
Oct 31, 2007 03:04 PM
DawnoffateX
11
Aug 31, 2006 11:48 PM
BluEvo3037
Jun 9, 2005 04:47 PM
