stroker kit
Old Jul 3, 2009 | 01:23 PM
BLAYZ's Avatar
Thumbs down stroker kit
any one think about doing a stroker kit instead of a turbo to a 4b12 if i can find the dementions could contact a manufacture if there is enough interest in this they would probably make them. toda makes some of the best kits for a bunch of other cars just asking what you guys think thanks
Old Jul 4, 2009 | 08:20 AM
jer301's Avatar
Sounds pretty cool. If there is anything I can do to help just PM me.
Old Jul 4, 2009 | 08:36 AM
EVO8904's Avatar
I think that you would get more out of 4b12 engine by putting a turbo on it. We already have a 2.4L so the main thing I would want to do is P&P the head and put more aggressive cams in it along with a turbo kit. And then you could put a methanol injection kit so you can run high boost.
Old Jul 5, 2009 | 12:47 AM
beowulfhuntr's Avatar
can you normally take your engine to get P&P at any shop? Nobody has upgraded internals for the 4b12 yet tho
Old Jul 5, 2009 | 04:50 AM
EVO8904's Avatar
Yeah, there are no internals for the block yet but I am wondering if the head on the 4b12 is the same as the 4b11. Most shops should be able to P&P a head but I would only go to a shop that is well known.
Old Jul 6, 2009 | 05:55 PM
09GTS's Avatar
Some shops that do custom stroker kits will make the pistons when the kit is ordered. I know that the Crower kit is compatible with the 2.4, they just make the pistons for you rather than sending a pre-made kit. Doesn't cost any more from what I understand and by choosing piston size you can change your compression.
I'd recommend doing a lot more to your internals before running meth injection w/ a Turbo thats set for high PSI. Good way to blow the motor.
Do your research, I'm not interested in working up my motor yet so I won't look it up, but certain parts in the motor, IE: Valves, valve springs, cams etc etc are already out there. Maybe heads too.. If you've got the 4B11 then you can pretty much Upgrade to Evo specs since they're already out there. Somebody had to make them for the Evo.. They're out there.
Old Jul 6, 2009 | 07:18 PM
EVO8904's Avatar
I bad tune will blow your motor faster than anything. I have had meth on several cars and the only one that blew was because a tuner did not know what he was doing and had my STI leaned out to AFR 17:1. You could pass on upgrading the valves as long as you don't plan on running your car at high rpms. I feel that our engines could handle high boost with meth and a good tune. Don't rely on a off the shelf map or a mail in flash. My first sports car was a 2003 WRX and I had it up to 21 psi with meth injection and no problems. 03 WRXs have weak engines...open deck blocks.
Old Jul 6, 2009 | 10:40 PM
Mayhem7o2's Avatar
Idk why people keep saying this, but the EVO 4b11t is not compatible with the 4b11. One shop says the cams may work but that shop also can't get their turbo lancer running (last I heard). If you have a 4b11 I wouldn't risk blowing your $15-22,ooo dollar car on high hopes . Personally I'd rather just turbo kit the lancer, the 4b's respond well to it... That is if you buy the right kit.
Old Jul 7, 2009 | 03:46 AM
EVO8904's Avatar
HOw do you know that the 4b11t is not compatible?
Old Jul 7, 2009 | 06:27 PM
BLAYZ's Avatar
yea but i have 4b12
Old Jul 7, 2009 | 06:57 PM
otter's Avatar
EvoM Administrator
Excuse my rudeness, but why the hell would you stroke a 2.4L 4 cylinder? There's a reason why manufacturers aren't in the habit of making 4 cylinder engines larger than 2.4-2.5L. The stroke becomes too long, meaning the engine can't rev worth ****, and further reducing the power band. Yeah, you might make some more torque down low, but you'll completely kill your high end horsepower.
Old Jul 7, 2009 | 07:00 PM
Smike's Avatar
This. Think about it. Google how strokers work. Better idea is to de-stroke and increase compression.
Old Jul 7, 2009 | 09:52 PM
09GTS's Avatar
The 4B11t wouldn't be directly compatible with the 4B11, in my eyes (And I am no mechanic do feel free to correct me), mostly because of the tune and the ECU. Those engines are managed differently than our regular 4B11/12's. So, in transferring Evo components into your engine, if you went all the way, you'd likely have to adopt the Evo's ECU as well or get a really good reflash/tune of your own ECU to support the modifications. It's a very smart motor but not smart enough to adapt to that big of a change without some outside help in terms of programming.
Again, this is just my humble opinion.
Old Jul 8, 2009 | 01:32 AM
Mayhem7o2's Avatar
do your research... this topic has been discussed a thousands times since they've been released. Only one shop has come forward saying there is a slight possibility the cams may work in a turbo'd lancer (same shop has been working on a turbo kit for over a year now, and just barely dynoed their prototype). But as it has been stated the 4b11t's compression ratio is different from that of a NA 4b11.
Old Jul 8, 2009 | 04:39 AM
EVO8904's Avatar
Yeah, I have done a lot of looking around and the only thing that I have found was people’s theories about how the engines are not compatible. The compression ratio has nothing to do with the cams or exhaust manifold being compatible. Another thing that does not determine if they are compatible is how the EVO is tuned differently. It would be stupid to put cams on a car and not have it tuned a sap. The problem that I am having with this is that no one has a clear answer and giving bullsh*t reasons for why they don’t believe that this will not work.
