DarkMitsu's 4g64 Swap Page
Old Sep 1, 2009 | 07:19 PM
darkmitsu's Avatar
the bad news I tried and tried for about 2 hours and could not get the axel to go into the transmission. The length is perfect the girth is perfect the teeth are the same, it would only go half way into the hole and no further...
I figure out how the lancer transmission comes apart and I extracted the differential I will be taking the eclipse Transmission back out of the lancer so I can swap the differential ...I double checked the eclipse transmission is definately a K5M422F6ND inscribed into the case..
Old Sep 2, 2009 | 04:31 PM
senate6268's Avatar
Originally Posted by darkmitsu
good news the ralliart drivers side axel showed up today ... the bad news I tried and tried for about 2 hours and could not get the axel to go into the transmission. I the length is perfect the girth is perfect the teeth are the same, it would only go half way into the hole and no further...
Well, after taking a second look at the Mitsu parts catalog, it turns out that although the Ralliart and 3G Eclipse share the same diff case, they have different spider gear kits. That's my bad. Sorry.
So it appears that swapping the Lancer diff into the Eclipse trans is the most practical way to perform the swap. At least they both use the same final drive gear so the ratio's are maintained.
Old Sep 2, 2009 | 09:32 PM
darkmitsu's Avatar
differential swap added ... changed / updated the thread...
Old Sep 3, 2009 | 08:02 PM
Daedalus2051's Avatar
Wow big project! Looks great so far man, thanks for the write up and keep up the good work!
Old Sep 6, 2009 | 07:18 PM
*02Lancer*'s Avatar
Wow tons of info! how long has the car been down and do you have a date you wont it done? Very nice work!
Old Sep 6, 2009 | 09:32 PM
darkmitsu's Avatar
Its been down for 10 days and its almost done i am waiting on a 10" slim radiator fan ... Now that I know all the stuff required and I made this right up, it can be done with 16-20 hours max ...
Old Sep 6, 2009 | 11:26 PM
initialg86's Avatar
Thumbs up
what tranny are you using??
is it off of an eclipse??
GREAT build btw
Old Sep 7, 2009 | 05:45 AM
darkmitsu's Avatar
It is the eclipse transmission with the lancer differential...
Old Sep 7, 2009 | 06:05 AM
Neteru's Avatar
nice wordk DarkMits. it looks like it came stock in the car. definitely turbo.
i have the same 4G64 head/block for sale if anyone's interested..
PM me.
Old Sep 7, 2009 | 12:40 PM
initialg86's Avatar
thank you just kinda confused
Old Sep 7, 2009 | 03:21 PM
darkmitsu's Avatar
kinda confused? tell me what I should clarify , see it all makes sense to me...
Old Sep 8, 2009 | 06:54 AM
darkmitsu's Avatar
!!!its alive!!!
Old Sep 8, 2009 | 07:09 AM
Jehuty's Avatar
It's up and running!?!?!!??! No problems?!?!?!
Old Sep 8, 2009 | 03:19 PM
darkmitsu's Avatar
That is correct just waiting on the 10" fans , but ive taken it out a few times on 1 fan, the temp stays between 212-225 but it hasn't been hot the past couple days so I'm trying not to drive it till the fans get here...
Old Sep 8, 2009 | 08:33 PM
Jehuty's Avatar
Damn dude, that's awesome.
