GTS with EVO X Cams
Old Feb 2, 2011 | 03:28 PM
derrickeliu's Avatar
cams info
Originally Posted by Raptor58559
Is the valve lift of the EVO X cams and the 4B11 ones the same?
Do you think it is possible to install them and drive 60-90 miles to the tuner?
So will i "loose" Power on the low end and gain some at higher RPM with the stock EVO X cams?
Michael
the valve lift of evo x engine 4B11T are higher than a 4b11 NA?I f You installed cams you will not have problems to get to your tuner , you can drive the car but dont do it agresively.you will gain power thru the entire rpm.
about cvt trannys i doesnot have info about how many power can hold.but i know that 4b11 na with 180 whp brake 1st and 2nd gear easily.this trannys are fragile
Old Feb 2, 2011 | 03:35 PM
Raptor58559's Avatar
Great!
So I'll get header, pulley and basic Flash now and throttlebody and cams later.
I was wondering if there ist still enough clerance between the valve and the piston.
Michael
Old Feb 2, 2011 | 05:33 PM
Evo10HKS's Avatar
really at only 180whp? and what exactly do you mean by "break"?
also with the tune, if i find someone who does tuning will they know what to do? or do i need a specific tune for these cams that only certain people have?
Old Feb 3, 2011 | 05:29 PM
Break i mean (destroy).it was a 5 speed manual(maybe bad driving). i recommend a mitsubishi tuner or a person that has experience tuning this cars. today a puerto rico lancer 08 gts 2.0 with evo x internals and turbo did 12.5@117mph 1/4 mile with street tires.soon more boost and slick tires .11.5 coming soon
Old Feb 3, 2011 | 07:51 PM
Destin_sinner's Avatar
Was that the mecanica Herodes car (Michael's car) ??? He's car is making i think almost 400whp and is a boost 08 gts with evo x internals...
Old Feb 4, 2011 | 05:31 PM
p1llar's Avatar
Thats a retardedly high trap speed. I went 104 and that was a 13.1 pass.
Old Feb 7, 2011 | 06:53 AM
lancer75's Avatar
do the evo x rods and pistons swap without any modification to the block? anyone know where i can find evo x rods and pistons?
Old Feb 7, 2011 | 05:42 PM
yitzac1990's Avatar
pistons yes, rods not without a new crank. on the internet
Old Feb 7, 2011 | 06:26 PM
Exactly as Yitzac said... in order to install evo x pistons and rods you are going to need an evo x crankshaft too. That with sleeves and injectors and a whole list of add ons is what made a local lancer here do a 12.4 in 1/4 mile with street tires at 18 psi at 117 mph...
thats fast...
Old Feb 7, 2011 | 06:32 PM
yitzac1990's Avatar
thats fast...
he might as well have just swapped in an evo motor. it goes right in lol
Old Feb 7, 2011 | 07:01 PM
lancer75's Avatar
what is the difference between the two cranks that makes you have to change them? is rod lenght different? what size is the combustion chamber on the evo x compared to the base lancer. im curious as to what compression you end up with when you swap the evo x pistons into the 4b11.
Old Feb 7, 2011 | 07:03 PM
lancer75's Avatar
thats fast...
why did he need to sleeve the block if the pistons just drop right in? its pretty much like building the whole shortblock?
Old Feb 7, 2011 | 07:04 PM
lancer75's Avatar
have you actually seen someone do this before i thought our trans wouldnt bolt up to the evo shortblock
Old Feb 7, 2011 | 08:58 PM
Evo10HKS's Avatar
yeah that sucks, theres no way the CVT cant handle 180whp though, the caliber RT has to put somwhere around 160, i doubt any car companies would put a tranny that close to its limit. but who knows.
Old Feb 7, 2011 | 09:54 PM
Nope is not a swap.... thats why he has been able to run just 18 psi at the most at least safely... since on the video post to you tube where they made 386 with 307 tq at 24 or 26 psi the car just lasted 2 weeks before breaking up.... so im guessing this time they are been conservative trying to know where's the limit of the engine...
Besides im on the same route with the crank, rods, pistons, sleeves, cams, intake and exhaust manifolds etc.....
