GTS with EVO X Cams
Old Mar 30, 2011 | 07:22 PM
  #76
dadsgts's Avatar
intake
Well intake is installed no issues there!! Used a evo x fuel rail custon return line to the tank and used a factory evo x fuel pump assembly with a evo x fuel pump. Also i went a step further and rather then using a exspensive evo x throttle body i used a eclipse 3.8 v6 tb and worked just fine. 65mm verses evo x 60 mm. All and all i would guess i hit the 250-260 whp mark. Thats also using a stock gts exhaust which is my next mod along with new cams ditching the stock evo 's and going with 272's now that i have the intake.
Old Mar 31, 2011 | 10:13 PM
  #77
villero1834's Avatar
Nice bro would thar tb bring any gains on na as well with stock fuel sistems or it would run kind of lean
Old Apr 1, 2011 | 12:35 PM
  #78
dadsgts's Avatar
You would have to have a fuel return line to run a evo x manifold since you cannot use the 4b11 na fuel rail with the evo x manifold without some pain in the a$$ mods to the stock fuel rail.
I wouldnt personally dump the cash into the intake swap on a na until somebody else does it. Theres no knowing if the less restrivtive intake will lose low end power. I would stick with a simple 4g69 throttle body upgrade for now. However if somebody has a spare none turbo manifold and stock na downpipe i will gladly install them, retune and have a dyno done to see if there is any gains for a na model!!
Old Apr 2, 2011 | 08:45 PM
  #79
Belgaram's Avatar
Little 411 on the 4B12 with Evo X cams... yes it can be done and I had everything ready to go.. Cams, followers, retainers, lobes, etc. And here is what I found out. the lobes are a problem. They are causing detonation and the cam sensor on the 4B12 is breaking, which is throwing off timing and breaking motors. Brian Crower and a few others are working on a fix for this. But no one seems to know if you can just put an Evo X cam sensor in instead. Glad I held off. Still doing the build, just minus the cams until they fix the sensor issue.
Old Apr 2, 2011 | 09:38 PM
  #80
ill be more than happy to lend u my 4b1 headers and down pipe once i get my ra manifold in, lmk well actually i have to let u know lol anyway ill let u try it but u got to give me sometime maybe another month
Old Apr 2, 2011 | 09:39 PM
  #81
dammm that sucks whose engine went boom , i was about to get the 272 cams but if thats the case ama hold on too
Old May 26, 2011 | 02:14 AM
  #82
boymay22's Avatar
i'm driving 4b11 cvt, with 4g69 tb, k&n intake and rrm header. if i change to stock evo x cam, how much whp would it get approximietly after ecu flash. will this set up safe for the trans? do i need to change the valve springs and retainer?
Old Jun 11, 2011 | 03:20 PM
  #83
LiX's Avatar
LiX
Evo X cams are 248, how much are NA 4B11 cams?
Old Jun 11, 2011 | 03:24 PM
  #84
LiX's Avatar
LiX
Originally Posted by lancer75
what is the difference between the two cranks that makes you have to change them? is rod lenght different? what size is the combustion chamber on the evo x compared to the base lancer. im curious as to what compression you end up with when you swap the evo x pistons into the 4b11.
I'm curious too what compression will be when you swap Evo X internals in 4B11 block.
I just ordered crank, pistons and rods from 12 000 mile Evo X.
Old Feb 16, 2012 | 09:28 AM
  #85
Hiboost's Avatar
Any updates on using stock Evo X cams in a 2.0L 4b11 NA engine?
I can fully tune the car on the dyno so it's just a matter of knowing if the lobes are really causing problems or if that was an isolated issue?
Old Feb 21, 2012 | 07:46 AM
  #86
al dopa's Avatar
I'd really like an answer to this question as well.
Old Feb 22, 2012 | 06:30 AM
  #87
derrickeliu's Avatar
Evo x cams
Evo x cams have higher valve lift duration.you can install the cams and drive
it to your tuner..illl be safe.you will gain low end torque.hp and benefit most in higher rpms.
Old Feb 22, 2012 | 06:38 AM
  #88
Originally Posted by Raptor58559
Is the valve lift of the EVO X cams and the 4B11 ones the same?
Do you think it is possible to install them and drive 60-90 miles to the tuner?
So will i "loose" Power on the low end and gain some at higher RPM with the stock EVO X cams?
Michael
Evo x cams valve lift are higher than 4b11 na.you can installed and drive it to your tuner.ill be safe.you will gain power from low to high rpm..
Old Feb 22, 2012 | 07:20 AM
  #89
boymay22's Avatar
at what rpm range does in gain much HP at high end?
Old Feb 22, 2012 | 10:05 PM
  #90
Hiboost's Avatar
Someone is really going to have to do a before and after dyno to show it is a worthy upgrade. It seems crazy that I may be the first one on my Outlander Sport 2.0L with all the other stuff on my plate... but I'll have multiple sets of Evo X cams sitting in front of me shortly so that might be a reality.
