Header choice
Old Feb 24, 2011 | 04:14 PM
holycrap300's Avatar
Header choice
I saw OBX header + dp for 195$ + shipping on ebay.
I saw that RRM sell header, but no downpipe?? If so i keep stock one? or make a custom one at exhaust shop?
Or i should only change nothing and keep stock one. ( headers + dp )
Since ill get a tune this spring, do it will be usefull or useless to change it or not.
I've got an High flow cat and 2.25" full catback.
What's your 2 cent guys?
Old Feb 24, 2011 | 07:38 PM
mci2727's Avatar
I have the OBX header/dP.
The down pipe takes the place of your factory down pipe and your under car cat.
So you can not run a cat with the OBX setup.
This is how I am running, both ofmy cats have been removed.
It makes your car tons louder, be ready for that.
I'm sure the RRM one is good, I just can't see paying that much for a header.
I believe it will help in adding power once you are tuned.
I know my car is running rich as hell and needs a tune bad, but I've also done about 10 other things to it.
But once I am able to lean mine out, watch out.
I think the OBX is made good, though others have had trouble with it.
But remember you will run catless.
Old Feb 26, 2011 | 05:12 PM
but i can run an high flow cat ? Or i should get an resonator?
Old Feb 26, 2011 | 05:17 PM
jakermeister's Avatar
RRM = Cat
OBX = No Cat
If you require a inspection/smog test in your state you should probably go with the RRM one. It uses the stock down pipe. It only eliminates the first cat on your exhaust header.
Old Feb 26, 2011 | 05:19 PM
nah i dont got that inspection here.
Old Feb 26, 2011 | 05:39 PM
OBX is a bit louder than RRM so its kind of up to you. I'm running a flow master and working on getting something else right now LOL
Old Feb 26, 2011 | 05:46 PM
ahaha, making too much noise? :P i'm looking for dynomax.
So with OBX i cant run high flow, interesting
With RRM one, it do a good job with stock downpipe? or i would be better making a custom one?
Old Feb 26, 2011 | 06:22 PM
The stock one should be fine but the obx sounds like it would run smoother (flow wise). No cat = no restrictions. Like i said, its really up to you. The flowmaster is too loud. I live on a reservation so anything goes LMAO!!!!!!!!!!!!!
Old Mar 3, 2011 | 05:13 PM
norcalrep707's Avatar
Originally Posted by jakermeister
RRM = Cat
OBX = No Cat
sucks cuz i WAS going to get obx but i just realized that its not carb legal....california sucks sometimes
Heebs 09gts
Lancer Engine Management / Tuning Forums
May 23, 2013 03:48 PM
04mralliart
Sep 6, 2012 03:43 PM
MELancer2006
Lancer Engine Tech
24
Jun 12, 2012 07:16 AM
holycrap300
Lancer Engine Tech
17
Jan 17, 2011 09:40 PM
xfreakx
14
Aug 31, 2007 01:45 PM
