Potential problem with valve seals (need advice)
Old Apr 8, 2012 | 09:49 AM
Evo Pete MTL's Avatar
I was just putting on my new turbo kit when I saw this:
Looks like I have a couple of valves leaking oil. Seems like I need to replace the valve seals. The valves are also white, looking like I ran lean quite a lot. Anything else I should look for?
Thanks. -Pete
Old Apr 12, 2012 | 07:46 AM
No replies? No one can give me input on this?
Anyways it looks like I have:
  • cylinder #1 intake valves leaking
  • and cylinder #3 exhaust valves leaking.
I just ran a compression test and the results were pretty positive:
  • cyl #1: 180
  • cyl #2: 175
  • cyl #3: 173
  • cyl #4: 178
Old Apr 12, 2012 | 04:04 PM
ryancb's Avatar
no clue man, I would just replace them if you have the head off. I think i paid $80 for a head set kit that had all the gaskets and stem seals. Car hasn't lost or burnt a drop of oil since.
Old Apr 12, 2012 | 07:31 PM
CrAnSwIcK's Avatar
pull the head replace all seals, clean the rockers, get valves reseated and lapped, do timing components and she'll run like new...it's not a full rebuild but it does wonders.
you can even bump up compression a bit, and port it if you want...but just new seals and a good cleaning should be fine...
Old Apr 14, 2012 | 09:30 AM
Thanks for the input. For now, I'll take the risk and install the setup. Hopefully nothing will break.
Old Apr 14, 2012 | 06:16 PM
mcgarvey's Avatar
No need to pull the head (or even the timing belt or camshaft) to change valve seals! I can change all the seals on a 4g94 in under two hours. With the rocker shaft off the head, it's a perfect time to clean out and bleed your hydraulic lash adjusters to get rid of the annoying tick most of these cars develop.
Buy a valve cover gasket and a valve seal set and you're good to go.
Old Apr 14, 2012 | 06:28 PM
corndog17's Avatar
I have an unused set of val ve stem seals for $30 shipped.
Old Feb 17, 2020 | 08:14 AM
John Francis's Avatar
advice on 2 hours or less
hi there. i am very interesting in how u do the seals and what tools u have to do the job any and all details are extremely helpful.
Ckeesee12
May 23, 2016 11:57 AM
rstchris
10
Jul 11, 2012 10:40 PM
fireroasted
13
Feb 8, 2012 03:30 PM
Spoolin18
23
Jun 30, 2011 02:01 PM
flandrs
25
Jan 16, 2011 11:26 PM
