ignition upgrade
Old Feb 17, 2004 | 11:47 AM
03RallyLancer's Avatar
ignition upgrade
I was reading through a book and it was discussing ignition and how at high rpms and under boost that spark plugs may not be able to fire at full strength and you should upgrade your ignition with like an msd or some such unit. Wondering if there is any truth to this? Just trying to get a list of parts im gonna get and prepair for turbo hopefully in a effort to save some money. So any of your guys opinions/experience would be appreciated.
Old Feb 17, 2004 | 12:30 PM
tenkawa_akito's Avatar
your typical distributor system is too slow to keep up with high rpm boosting. not to say that distro ignition is flawed, it's just not as strong in high rpm boosting. you can alleviate the problem with better plug wires, better plugs, etc, but the best type of ignition for a turbo car is (in my opinion) direct coil on plug where each plug gets a seperate coil to drive it instead of one coil driving all cylinders. they're generally more accurate due to electronics.
For low boost applications, the ignition doesn't need to be upgraded, but say you decide one day to blow a high amount of boost into your engine, your ignition system will need to be upgraded. For now, don't worry too much about the system, buy some magnacore wires from RRM and you should be ok.
Old Feb 17, 2004 | 12:34 PM
HobieKopek's Avatar
We have distributorless ignitions. We fire off two coil packs.
Ideally, yes. 4 direct fire coilpacks is ideal. For all practical purposes the stock ignition should be fine however. If anything just replace the wires and plugs if you have a power loss.
Old Feb 17, 2004 | 12:38 PM
well i was plannin on getting some wires and plugs... i was just wondering about a "piggyback" ignition box. thanks guys.
Old Feb 17, 2004 | 12:47 PM
you guys don't use distros? that's cute
yeah, save your money for now and stay with your stock ignition and just get some plugs and wires. you should be fine there.
Old Feb 17, 2004 | 12:55 PM
HobieKopek's Avatar
All recent year Mitsubishis that I'm aware of (at least in the US) use 2 coil wasted spark ignition systems.
Old Feb 17, 2004 | 12:59 PM
you guys are finally catching up to nissan. Took you long enough
heh. just pulled out my old hayne's manual for my '91 eclipse and it used a DIS. I take back my statement of you guys being behind the book
Old Feb 18, 2004 | 09:28 PM
KillahB's Avatar
Dont know about you Lancer guys but us smaller engine 1.8ers cant use MSD as our ignition tool.... the MSD frieds the coilpacks. We have to stick with simple plugs and wires as our ignition upgrades, even tho some of have gone SITC to adjust the timing.
Old Feb 18, 2004 | 11:10 PM
HobieKopek's Avatar
We had one user (joshkita) with a lovely horror story with his MSD DIS-2 ignition. Maybe you guys know something we don't or have a different ignition system.
Old Feb 19, 2004 | 10:47 AM
KillahB's Avatar
I think our ignition systems are similar but I am not sure. I personally have not examined in great detail the 4G94 engines. I will ask bahamut and see since he has had a ton of experience with both engines.
Basically for the few Miragers that tried it, it fried their coilpacks and ECU in a few instances. Our coil resistors cannot handle that kind of power.. Theoretically (yeah I know I am all theory, but I am too poor to try), to get it to work for us, we have to run aftermarket coil packs and build a feedback circuit liek the Supra guys.
Old Feb 19, 2004 | 02:26 PM
HobieKopek's Avatar
I think that's exactly what happened to him. Blown coil pack(s) and ECU.
Raceghost
Jun 20, 2012 02:52 PM
bbyevo8u
Dec 20, 2009 09:28 AM
Soon2BEVO
22
Mar 29, 2007 07:27 AM
teamdomokun
Automotosports - Illinois
Jun 13, 2005 08:45 AM
PaulysLANCER
Lancer Engine Tech
10
Dec 13, 2004 12:08 PM
