Dyno'd lancers list
they couldn't get an RPM reading from my car so all i got was AFR and HP readings. i was a little dissappointed. i was hoping for 115 and only hit 108.88 i still have an exhaust leak to fix though. ...not to mention leaning out a little more would help. results were recorded on a DynoJet in a 4th gear pull.
Mods list: CAI, 4g94 P&P Intake Mani, Custom P&P Exhaust Mani, 2.25in Downpipe, 2.25in Cat Back, PB ECU v.1.0, Magnacore Plug Wires, RRM CS Pulley, Clutchmasters Flywheel, Kaaz LSD, RRM Big Bore Fuel Rail.
i'm not going to bother with correcting the AFR's. i don't have the software and it would be deemed useless once i toss EMS in the car. but there's some numbers to start with for me.
mark
mark
AEM EMS...that won't be till next spring though. i'm more concerned with boosting first. then i can tune that fuel map until i get the AEM in the car...i was talking to the guy who did the dyno and he said if i were to correct the AFR's alone they should yeild 5-10+ ......12.6:1 is pretty rich. i figure between correcting that and fixing my exhaust leak i could HOPEFULLY make 120whp....then again, that's only wishful thinking.
btw, my engine is starting to feel a little.....let's say, tired. it doesn't have the same up-and-go that it used too. the high miles might be started to have an adverse effect (64k)
No, 12.6 is right where you want to be with this engine- the ECU is tuned for 10.5-11 depending on the weather. C'mon man, you've read the posts, you know Boe has seen dudes tune for 13.5 and melt stuff. Don't get greedy. It's a sad fact that this engine does not respond well to basic and even more advanced mods (ported manifolds and fuel tuning for example). Mitsu gave us about as much as they could get out of the G93 by boring it out to 1.998L. Dave at RPW has been saying this since the car came out- even with cam, twin TB, headwork, exhaust, pistons and eManage you're not going to break 160 NA. I don't know how the G69 engine mods but I imagine it's more responsive to basic stuff. Your exhaust leak won't be a miracle solution but might get you to break the 120 mark and it will stop feeling anemic. If you have a test pipe or high flow cat you might want to put the stock cat back on... but you can find the pages and pages of discussion about why that does/does not work- I won't start it again here
I really am being sympathetic- check my mods list
It shouldn't come as any surprise that I'm not rushing to spend the money do the next mods
I know this is not really a big discussion thread but I just wanted to throw in me 2c.
Although you custom ported the stock exhaust manifold it is probably still restrictive enough to disallow proper air flow from the engine. You have a whole bunch more air coming in but it still probably doesn't have the room to exit.
With your mods list that is the only thing I see that might hinder performance.
WADAD
WADAD
my goal is to hit 120whp before boosting. i need to do a really good tune up like greg said. i'm picking up another RRM header and fixing up my leaks. if that doesn't help then so be it. boosting will be next. thanks for the input.
btw, i still have a cat on the car.
Originally Posted by Boe
NA try to stay around 13:1 for 91+
Around 12.5-12.8:1 for 87-89 octane.
not bad. with a header and a pulley you should be over 120hp/tq
